Rear Footrests
GBZ1000
Rear Footrests
#1 PostAuthor: GBZ1000 » Fri Jun 09, 2023 9:28 am
Looking for help to solve a puzzle on the rear footrests. I was looking to order some new footrest rubber bushes, but the ZPower website and the Haynes manual show a different rear footrest arrangement that the ones on my bike.
I’ve attached a couple of photos that show how my rear footrests are mounted. Are they wrong for a 1977 Z1000A1. And if so, can anybody help me understand what is going on?
I’m aware that the brackets have been cut and welded for some reason, but the Haynes manual shows the rear foot rests bolted directly to a tubular frame section. Mine has a “flat” plate carrying the footrests.
Graham
z2.john
Re: Rear Footrests
#2 PostAuthor: z2.john » Fri Jun 09, 2023 9:55 am
That is the Z650 set up that someone has done
Re: Rear Footrests
#3 PostAuthor: z1bman » Fri Jun 09, 2023 11:15 am
They are correct but someone has sawn off the original mounting that was circular & threaded to 10mm & have just welded a piece of flat steel in its place
z2.john
Re: Rear Footrests
#4 PostAuthor: z2.john » Fri Jun 09, 2023 2:10 pm
z2.john wrote:That is the Z650 set up that someone has done
My error. Of course it is also for Z1000 as well as Z650
Re: Rear Footrests
#5 PostAuthor: ADRIAN H » Fri Jun 09, 2023 2:39 pm
The footrests are correct, someone has added or welded a metal bracket on. Same for Z650
GBZ1000
Re: Rear Footrests
#6 PostAuthor: GBZ1000 » Fri Jun 09, 2023 8:50 pm
Thanks for the replies.
Graham
Re: Rear Footrests
#7 PostAuthor: warren3200gt » Sat Jun 10, 2023 8:35 am
Correct. Looks like yours had rotted out at the bottom half and po has sourced good ones and chopped off the rotted part and welded on good half. Shame they didn't take the time to get them straight and clean the weld up.
s-l1600 (8)-1.jpg (142.11 KiB) Viewed 3059 times
Pic from khi workshop manual.
GBZ1000
Re: Rear Footrests
#8 PostAuthor: GBZ1000 » Tue Jul 11, 2023 9:36 am
warren3200gt wrote:Correct. Looks like yours had rotted out at the bottom half and po has sourced good ones and chopped off the rotted part and welded on good half. Shame they didn't take the time to get them straight and clean the weld up.
Thanks for the pic and the feedback Warren. Apologies for the delayed reply, but I’m still not getting notifications on replies to my posts.
Graham
Re: Rear Footrests
#9 PostAuthor: warren3200gt » Tue Jul 11, 2023 10:00 am
Similar to Z650 but mounted totally different position and angle on a Z650.
1 (1) (2).jpg (110.66 KiB) Viewed 2947 times
Users browsing this forum: Jigginjim and 63 guests
