Carb promlem
Mark Mitchell
Carb promlem
Hi All, hoping someone might be able to help. Problem is number 3 carb on my Z1000A1 leaks a small amount of fuel when left standing overnight. i have had the carbs off cleaned and replaced seats and valves with new. Also adjusted float hieghts but no luck! The bike is left on the side stand and the fuel tap is off, although i have noticed that the tap weeps slightly in the off position. (Got new tap on order from Zpower) Bike seems to run well other than that. Had lots of advice and had a go at all thats been suggested. Don't know what else i can do. Is it just a case of getting the correct float hieght right ??
Would very much appriciate some help from anyone out there.
PS. Bike is fitted with standard Mikuni carbs.
Mark Bristol.
Mark Bristol.
Mark Mitchell
zeroed
Mark Mitchell
Carb problem
Thanks all for your help,
I have fitted in-line filters and got block under the side stand.Got a new fuel tap on order i will try this and see what happens.
Mark
Mark
PaulMceleney
- Chunks
Mark Mitchell
Carb problem
Thanks again for all the advise, I've just recived my new fuel tap & in -line filters which i'll fit tomorrow. Feeling confident that this will work after talking to you guys.
Regards to you all.
Regards to you all.
Users browsing this forum: No registered users and 110 guests
