Valve Timing
evans
Valve Timing
#1 PostAuthor: evans » Mon Apr 06, 2009 6:25 pm
Just replaced the head gasket on my z1000A1, but now bike wont start. Timing mark on the exhaust cam sprocket in manual shows a single mark which should correspond to a pin in the cam shaft. But mine has a mark either side of the sprocket which correspond to teeth on the sprocket. So these cams maybe replacements. Could it be that I have the exhaust can 180 degrees out ? Have good spark and fuel.
Chris
#2 PostAuthor: Pigford » Mon Apr 06, 2009 6:31 pm
Chris.... if you've already been spinning the motor.....
Whip the plugs out and check for compression on all pots.....
If way out the valves will be bent (worst case) or no compression coz timings so far adrift :??
evans
#3 PostAuthor: evans » Mon Apr 06, 2009 7:12 pm
Surely I would have heard a noise if valves were bent. No noise at all just wouldn't start ? I di make sure that nothing was going to touch etc by turning the engine slowly by hand before I put the rocker back on.
Chris
#4 PostAuthor: Rich » Mon Apr 06, 2009 7:20 pm
Have you put the advance retard cam lobe on the right way?
evans
#5 PostAuthor: evans » Mon Apr 06, 2009 7:36 pm
Bike has been running great since I put the dyna coils and ignition on.
Not starting since I did the gasket etc. Definitley valve timing but surely I would have heard a crunch if something serious had happend ?
Chris
#6 PostAuthor: Pigford » Mon Apr 06, 2009 8:00 pm
If you turned over carefully by hand....... should have felt contact.
If kicked or electric start..... may not have noticed if only just touched.... but enuff to bend valves.... I know... been there, dun that, got the T-shirt & bill :cry:
That is worst case senario, so probably not that bad :wink:
Is there compression on all 4 cylinders :?:
#7 PostAuthor: chrisu » Mon Apr 06, 2009 8:05 pm
do a search for the problems bigmac had when he did the same thing. not pretty.
evans
#8 PostAuthor: evans » Mon Apr 06, 2009 8:13 pm
Definitely no contact when I turned it over by hand ?
evans
#9 PostAuthor: evans » Mon Apr 06, 2009 8:18 pm
Pigford, what should the compression be, will go and test it now.
#10 PostAuthor: chrisu » Mon Apr 06, 2009 8:19 pm
could just be out then if you're lucky
have you checked against this diagram ?
I'd still want to do a compression test..........
#11 PostAuthor: Pigford » Mon Apr 06, 2009 8:21 pm
If you have a tester... cold.... a good +100 ....
If no tester, plugs out, thumb over each plughole whilst cranking... should POP your thumb off each comp stroke (alternate turns) :wink:
Good luck :shock:
evans
#12 PostAuthor: evans » Mon Apr 06, 2009 8:48 pm
Compression very low, 1 - 30psi, 2 - 30psi, 3 - 0psi, 4 - 25psi.
In the diagram above where it shows the timing mark level with the top of the head on the exhaust cam sprocket, mine has a continuous line right across, so you don't know which way round it should be. The marks also match to a tooth rather than a pin in the cam chain. I know that I should have checked and marked the positions before removal, but assumed they were standard as in the diagram.
chris
#13 PostAuthor: Pigford » Mon Apr 06, 2009 9:30 pm
From memory, as you look at the end cam lobes, they are either both facing in or both out (on a horizontal plain) :??
That is low... but I'd expect 0 psi if valves bent, so may just be cams out.... or valves only just touched... still f**ked though if they did. :??
Need to establish true valve timing before weeping/praying/drinking... :!:
evans
#14 PostAuthor: evans » Mon Apr 06, 2009 9:44 pm
Pigford, cheers for the info, will take the cams out and review, suppose I can't tell if I have actually done anything to the valves unless I remove them. Suppose I can reset as you suggest, put back togther and see if it starts.
I can't believe you bent valves as you seem to know all about this sort of stuff.
thanks
Chris
PS Anyone replaced cams with ones with timing marks that sound like mine ?
evans
#15 PostAuthor: evans » Tue Apr 07, 2009 2:02 pm
So does anyone know how to set up the valve timing in the absence of timing mark 4 as shown in the drawing above on the exhaust cam sprocket ?????
I understand that when 1&4 cylinders are at TDC (T mark) then this is the rocker position, from which point rotating engine forward cylinder 1 exhaust should start openening but rotating back cylinder 1 inlet should just start opening. How do I know when this point is and from where to count the 28 pins in the cam chain??
Any help much appreciated.
Chris
Users browsing this forum: No registered users and 76 guests
