another carb thread
zeroed
another carb thread
#1 PostAuthor: zeroed » Fri Mar 06, 2009 7:54 pm
just bought a kz1000b4 ,stripped down rear end for an overhaul, went to clean the carbs today :..someone`s butchered some of the screw heads.
Is there a new set (Mukini`s?) i could bolt straight on for peace of mind? without spending telephone numbers :nik : :oh
Or a local guy said he can overhaul the old set.Think i`m a perfectionist :??
tlc
#2 PostAuthor: tlc » Fri Mar 06, 2009 8:04 pm
Do you mean the screws or the threads in the carb bodies ?
zeroed
#3 PostAuthor: zeroed » Fri Mar 06, 2009 8:15 pm
one thread in the actual carb body is stripped,and two drain plugs wont budge and the screw heads are chewed up, so i was thinking of maybe replacing the whole lot ,depending on price. :?? it`s turning out to be an expensive project :roll: :lol: would like some advice/wondered if a new modern set would bolt straight on?
tlc
#4 PostAuthor: tlc » Fri Mar 06, 2009 8:23 pm
That`ll cost a lot.
Post piccies of the knackered body.
And warm the screws that won`t come undone, let them partially cool and try again. Might have to do this several times before they shift :evil:
Patience is the key here :(
zeroed
#5 PostAuthor: zeroed » Fri Mar 06, 2009 8:28 pm
yeah i can`t justify spending £500-£1000+? . A guy i know reckons it`s not a problem to restore the thread, thinking of just dumping the carbs on him to overhaul professionally.
Nothings unfixable..i hope
sweptail
#6 PostAuthor: sweptail » Fri Mar 06, 2009 8:45 pm
zeroed. Have a word with Ste Cooke; he`s in your area and is very good on carbs. Tommy
