reg/rec
- mick znone
reg/rec
my computer wont let me do a forum search, much head banging on wall
so here is a much repeated question. these combined reg/rec units, are they really easy to fit
do they look quite different
is it easy to tell if i already have one fitted
should i just get Phil at zpower to throw one in the post
get one from phil.
they simply screw under the battery box (as the old one ) and just plug in to the original plugs, well the one i got from jeff at z1enterprises did. There will be a gap behind the side panel where the other part has been removed just above the 4 large block connectors. (unless you want to leave it looking original).
modern electrics work much better than the old stuff.
http://www.z1enterprises.com/detail.aspx?ID=261
thats what they look like, the original part fitted under the battery box will be silver in colour and more like a tin, (smooth shape rather than ribbed).
pressume this is like the one from electrex. was cheaper from the usa once but not now.
http://www.z1enterprises.com/detail.aspx?ID=445
Just found rec/reg on Zpower site
https://www.z-power.co.uk/merchantmanag ... ucts_id=41
This is similar to the one from Z1 enterprises, just plug & play NO faffing about soldering/crimping....Whatever.
I priced up the Z1 enterprises item last week & it came in at around £90 inc shipping.
I guess with club discount, & after postage the Zpower item will cost the same.
I reckon you'll go for the plug n' play option Mick....... Why make life difficult, eh?
- Geoff Meager
- mick znone
brilliant guys, THANKS
. sorry to repeat question, i saw your recent thread Bear, but couldn't watch the blue circle go round and round any longer
part ordered from zp. you're right Bear, why make life difficult. its funny, i used to do all my own work on bikes, but i lived with bikers, these days i spend all day fixing peoples houses and dont want to do any of my own stuff. work, surf, ride, travel.
- mick znone
