usd forks
- london calling
- big green bus
lawsom34
- london calling
- london calling
I suppose you've got to compare the length of the standard Kawasaki forks with the GSXR ones and decide if they're going to be long enough and provide enough ground clearance.
Also the GSXR forks will be sprung for a much lighter bike,so maybe you should look at different springs,etc.
Also fork seal replacement on USD forks can be quite involved,depending on the make.
Jack
- big green bus
yamaha tend to be longer as they mount the clipons on top of the yokes yzf 750 are ok. most of the kawasaki ones tend to be too short. the wheel could hit the exhaust under heavy braking or flatten the bottom of a 4/1 pipe like a harris. i would get a tape measure and look at as many bikes as possible.
750 Forks with the six pots are most likely to be zx7r forks, they are from memory 2" shorter than standard z1000 forks.
However when I measured my gpz11 probably the same as the 1000j they were even longer than a standard 1000.
My records show
z1000 being 31.5"
zrx1100 being 30.5"
gpz11 being 34"
so that would make zx7r ones 29.5 from the top edge to the middle of the spindle. (zx9rb forks are supposed to be a couple of inch longer and the b2's onwards had 6 pots the same as the zx7r)
So zx7r ones would be well short especially with a 17" wheel. However all is not lost.
IZAX Engineering can make offset yokes upto 1.5" approx £450 however the better option would be to get the forks to Maxton engineering who can extend the forks and set them up to the right weight for the rider and new bike, so they work properly. The bad news its approx £500 again.
Hope this helps.
My records show
z1000 being 31.5"
zrx1100 being 30.5"
gpz11 being 34"
Hope this helps.
gsxr forks are 2" to short plus smaller wheel. you will have to extend them or make a steped yolk!!! standard z stem won't fit in gsxr bottom yolk if you are using the gsxr k series front ends as bottom yolk is fatter
and it's not long enough
so you will have to make a new one!! i am getting one made next week for my bike the one on link above. if you are only after upside down forks and are not bothered about having a modern set get a set off a FZR 100RU as they will be long enough and cheeper than gsxr ones
Users browsing this forum: Bing [Bot] and 75 guests
