Pigfords OLD effort......now JULES NEW PROJECT!!!!!
Rich wrote:You can get the selector forks in after putting the cases together, saves farting about lining things up
Hmmmmmm, yeah, but the "farting about" bit is good coz it leads to achievement against the odds...and finally "self-satisfaction"
But
....Re-did me calipers tonite..... whacked in bit of red rubber grease to keep the damp at bay
Mrs P even let me do it in the front room....
Fitted the new oil seals x3 to the sprocket casing tonite and whacked that back on
Also fitted the APE heavy duty studs
Oh, and I won this the other nite... good old eBay....
Not quite a JMC
but OK for £26
Not quite a JMC
PaulMceleney
- Chunks
Greg it was off a Z1000J
So It'll be just right for me Lawson...
I've got a JMC concentric arm at the moment, but I intent to run this bike down the strip too, so that extra few inches will make all the difference
I also have a spare set of Gixxer wheels (120 x17 & 180 x 17)
- london calling
Hey Jack-m-Lad...
Well..... its been one of those days.....
Thought I'd pop out to the garage for an hour & whack me short engine back in the Lawson frame......
OK for a one man job - frames still tatty so don't have to go too careful
Anyhow...... after 1/2 hour things were not going as planned...
Got rear mount in & the front lot were well "squiffy"...
Had to use a broom handle to gently persuade the front bottom to line up...
Feck.... this bike is a real Munter....
The feckin' frames twisted
Notice the "fine-adjustment" tool on the right
After another 1/2 hour of "pushing & pulling"....NO JOY.... I decided to do the proper thing... CUPPA TEA & a BISCUIT (loads of them special Chocky Xmas ones laying about).
Back in the garage I had another 15mins struggling... then... EUREKA
Problem solved....
Only had the rear spacers arse about face......
Problem solved....
Re: let down
ted1r wrote:You`ve let me down I thought you were perfect![]()
Ted
I am Perfik Ted.... it just took a cuppa & a bicky......
Gonna get in the garage tomorrow (hopefully) & fit pistons & barrels...
Its gonna be a shame to get those loverly WISECO's covered in oil & carbon...
- paul doran
Re: let down
Ted
jeez Ted you were in the minority there
The Piglet prefect what a laugh
