Professional carb cleaners ?
- london calling
Ring round your local bike shops,maybe a carb specialist or dyno centre would have an ultra-sonic cleaning tank.Most automotive engineering firms will have them to get metallic parts perfectly cleaned.
The carbs have to be stripped,all jets removed,etc so it is quite a labour intensive process but the results are worth it.
I'm getting some done for "Bling Master" Dale and i'll be down to see him soon in Harlow,so if you don't have any luck locally maybe i can help you out.
What carbs are they??
Jack
Magik
- london calling
JRS have a good reputation for this work and can be contacted on 01792 402458 website www.jrs.uk.com or e mail ultracleancarbs@jrs.uk.com
Ian.
Ian.
PUM 13
I've used a company called 'Carb Exchange' on 01525 371369 based in Leighton Buzzard. They do an excellent job and bring the carb bodies back to just about how they looked when new, ie. a natural 'gun-metal' finish. Some carbs that I've seen end up far too shiny...but still, it depends on what you are looking for. Carb Exchange charge approx ?9 per carb...by the way, don't be put off by the name...they don't actually exchange your carbs for some they already have, it's yours that are chemically cleaned.
Hope this helps.
Steve
Hope this helps.
Steve
- Jeff Saunders
Ultrasonic cleaning can be good - one caution, all moving parts should be removed from the carbs. If you leave float needles in the seats, the vibrations will damage the seat and needle. You can have the same problem with the needle / needle jets, accelerator pump parts, etc.
I phoned them up quoted ?7 aswell, carbs stripped and taking them up there this week. steve if you are anywhere near watford on route to buzzard I can collect yours and take them for you. save postage.
how long does the process take, can i wait or do i have to return another day..?
Cheers BunnyZ,
Didnt ask how long it takes to do,presumed I would drop off and pick up at a later date, will have to find out.
I shouldnt think it takes long to do depending on their workload I didnt fancy posting them what with Xmas looming!
I,m in Reigate which is about 45min from Watford might be able to sort something out to share the travelling,when were you thinking of going?
Are you doing float bowls as well?.
Steve s
Steve s
Users browsing this forum: sockpuppet and 35 guests
