Gpz 1100 a1 hazard lights
stusco
#1 PostAuthor: stusco » Sat Jun 29, 2024 12:24 pm
The hazards on my gpz don’t flash the indicator’s work fine ,when I switch to the hazards i can hear the relay clicking but no flash(ive just replaced the relay) no difference
Re: Gpz 1100 a1 hazard lights
#2 PostAuthor: Philippe » Sun Jun 30, 2024 3:51 am
Hi stusco
is the relay clicking only once or repeatedly? If the hazard relay is good and the indicators are working properly there must be a problem with the switch.
I think you have a bad grounding on the hazard switch (broken wire, loose wire, bad connection,...)
I hope you can find the solution. Bike electricity can be a real pain in the ...
stusco
#3 PostAuthor: stusco » Sun Jun 30, 2024 10:15 am
Thanks its multiple clicking
