Coils. Resistors? Z1000A1
drydockdavies
#1 PostAuthor: drydockdavies » Sat Jun 15, 2024 2:56 pm
Z1000A '77.
Just in the process of changing the coils, I'm replacing with Z Power parts shown. Is this a resistor? There is only one mounted under the right coil, cylinder 2/3. Do I still need it? It would have been like this since the late 80's when the frame was sprayed. I'm using NGK B8E S sparkplugs. The more I read up on resistors the more confused I get!!
z2.john
Re: Coils. Resistors? Z1000A1
#2 PostAuthor: z2.john » Sat Jun 15, 2024 3:08 pm
It's nothing to do with coils. It relates to the headlight. It connects to the blue wires on the RH and LH switch blocks
drydockdavies
#3 PostAuthor: drydockdavies » Sat Jun 15, 2024 3:41 pm
Thanks a lot, I will junk it then. It's had its wires plugged together since....
Are there resistors in the NGK plug caps? What plugs would anyone recommend?
#4 PostAuthor: warren3200gt » Sat Jun 15, 2024 4:45 pm
Red ngk plug caps have 5 ohm resistors.
Black ngk plug cap have no resistors.
B8ES have no resistors.
B8RES have 5 ohm resistors in the plug.
Only one or none max resistors per ignition line to each cylinder.
Denso W24ES are equivalent to ngk B8ES but in my opinion are far better plugs, more forgiving, more reliable and better lasting.
drydockdavies
#5 PostAuthor: drydockdavies » Sat Jun 15, 2024 8:57 pm
So as long as I don't use red caps with a resistor plug, B8RES, everything will be ok?
Black caps and Denso plugs is the way I'll go.
Thanks for your help.
#6 PostAuthor: warren3200gt » Sat Jun 15, 2024 9:10 pm
Yes, one or none resistors per line.
W22es is equiv to B7ES if you want to go slightly hotter plugs.
drydockdavies
#7 PostAuthor: drydockdavies » Sat Jun 15, 2024 9:17 pm
warren3200gt wrote:Yes, one or none resistors per line.
Many thanks
Kev1R
#8 PostAuthor: Kev1R » Sun Jun 16, 2024 10:10 am
I bought this coils and caps kit from Zpower a couple of weeks ago. The red caps option was not available so it came with black NGK plugs.
My black LB05F plugs are stamped 5K ohm so black plugs having no resistor is not a hard and fast rule.
Just something to be aware of.
010
gray
#9 PostAuthor: gray » Mon Jun 17, 2024 8:00 pm
I remember when I was restoring an XL185 it has a "ballast resistor" connected in the headlight circuit. it was broken so I deleted it and just joined the wiring ends together , but then it started blowing headlight bulbs - turns out it damped down surges in voltage/ampage when revving , which could lead to blown bulbs through overload. Prob was sorted when I found one and refitted it. So it may actually do something - if you delete it then watch for electrical issues elsewhere
gray
drydockdavies
#10 PostAuthor: drydockdavies » Tue Jun 18, 2024 7:47 pm
gray wrote:I remember when I was restoring an XL185 it has a "ballast resistor" connected in the headlight circuit. it was broken so I deleted it and just joined the wiring ends together , but then it started blowing headlight bulbs - turns out it damped down surges in voltage/ampage when revving , which could lead to blown bulbs through overload. Prob was sorted when I found one and refitted it. So it may actually do something - if you delete it then watch for electrical issues elsewhere
Many thanks, I discovered it as pictured, the blue wires are connected together and have been for 30 years.
drydockdavies
#11 PostAuthor: drydockdavies » Tue Jun 18, 2024 7:48 pm
Kev1R wrote:I bought this coils and caps kit from Zpower a couple of weeks ago. The red caps option was not available so it came with black NGK plugs.
Many thanks, I'll check.
