Z900 A4 1 owner from new . First registered 19-10-1976 . New vehicle order form dated 16-10-1976 from Doncaster Kawasaki Centre . Only 10,581 miles from new .
The bike is not 100% standard . Stainless steel rims and spokes have been fitted along with stainless fasteners and Koni shocks . The engine has been fitted with a Yoshi 984cc kit along with Yoshi R&T cams and Yoshi valve springs . Dyna S ignition and Dyna coils and Dyna leads are fitted . The bottom fins on the head have been modified as can be seen in the photos . This was done either because of the fairing or oil cooler lines that were fitted at the time , this was done 45 years ago and memories are not what they used to be .
The bikes owner moved to Australia and the bike has sat in his mums garage for 12 years under a protective layer of thick oil and grease .
I have cleaned all the gunge off . The fuel tap and carbs have been stripped and rebuilt . The front master cylinder has been rebuilt . New air filter , oil and oil filter fitted . Kawasaki parts used . The bike runs really nice and sounds sweet . The bike is on SORN .
A new owner is needed to look after this bike and ensure it gets used .
£15,000 .
I am doing this to help a friend and and have no monetary interest in the sale of the bike .
fer
1976 z900A4
1976 z900A4
Re: 1976 z900A4
Smart looking A4
it’ll go bit with that Yoshi stuff…
Re: 1976 z900A4
The bike has now started the journey to Australia to be reunited with its owner .
fer
fer
Re: 1976 z900A4
ah brilliant same owner from new i bet he cant wait for it to arrive
- paul doran
- Sgt.Pinback
