Gpz1100 unitrak clutch help
rpeters
Bristol's "H" Hoarder
#1 PostAuthor: rpeters » Wed Jul 19, 2023 4:38 pm
Recently purchased gpz1100 a1. Now starts and runs fine, just MOTd. Engine had noisy clatter from clutch side. Have removed pressure plate and found this. I can’t correlate the set up to the supplement manual diagram. I and guessing these two pieces should be one piece?
Rob
paid up member
Gus
Re: Gpz1100 unitrak clutch help
#2 PostAuthor: Gus » Wed Jul 19, 2023 5:50 pm
Hi Rob.
Any help?
Gus
"Set the GRINDER on it"
#3 PostAuthor: zed1015 » Wed Jul 19, 2023 6:08 pm
Appears to be parts 92043 and 92026A which are seperate parts..
gray
#4 PostAuthor: gray » Wed Jul 19, 2023 6:39 pm
could the springs be worn out between the clutch outer basket and the outer gear? Buzzard did an article some years ago on his setup for fixing this
gray
rpeters
#5 PostAuthor: rpeters » Thu Jul 20, 2023 5:01 am
thanks guys, yes looks correct Rob, the supplement shows the pusher set up in the box which is where I confused!....
I will remove the basket today and look check. is there a topic link to Buzzards thread??
cheers
Rob
paid up member
gray
#6 PostAuthor: gray » Sun Jul 23, 2023 6:48 pm
it was in the 2019 yearbook and there is an article in Classic Motorcycle Mechanics - Feb 2020 according to my "reference library"
gray
rpeters
#7 PostAuthor: rpeters » Wed Aug 02, 2023 6:40 am
Does anyone happen to have the 2019 club mag and can copy the article for me please?
THanks
Rob
paid up member
marmck
#8 PostAuthor: marmck » Wed Aug 02, 2023 8:00 am
Hope this helps
rpeters
#9 PostAuthor: rpeters » Wed Aug 02, 2023 8:21 am
Thanks, its interestin, but i just put up another post.....cant even get the bleedin clutch out!
paid up member
Users browsing this forum: marmck and 90 guests
