Hi yesterday my starter motor was working just fine today not working at all connnections are good what can I check and how I have no specialist electrical testing gear any help much appreciated
Ta Paul
Starter motor problem
- warren3200gt
Re: Starter motor problem
Try switching the kill switch from off to run a few times to clean the internal contacts. I assume you are trying it with the kill switch in the run position?
Have tried that one
- warren3200gt
Chances are it's going to be a kill switch fault. They aren't the most robust internally.
Easy to check if it's the starter motor, just whip it out, place on the floor and stick your foot on it. Earth the body and live to the terminal and see if it spins up.
Right have now got the starter going it was the four way connector from the headlamp under the tank I thought great but now I have NO spark I have Dyna s ignition fitted so have pulled each connector for this in turn cleaned bullets with fine sandpaper to bright metal and made sure each connection was tight tried spinning motor after each one and no spark at any of the plugs.
If I had any hair would have pulled it all out.
What do I look at next I have no electrical testing gear.
Any help much appreciated is driving me nuts
- warren3200gt
At the very least make up a test bulb as you need some way of test if you have live at various points.
Better still go buy a multimeter, they are only £20.
- Z1streetfighter71
- ZedHead
I hope not off topic but has anyone done a "Big4" full starter motor rebuild thread on here or does anyone know of a good one?
On facebook Z1 owners nils menten
no spark at all , on any cylinder suggests to me kill switch, the block connector for the R switchgear, ignition switch or the block connector that feeds it, or a fuse ( but then you might have no idiot lights too). If you've got the tank off then easy to check the block connectors and see if 1 pin on a block connector has been pushed back and isn't making good contact
gray
Users browsing this forum: marmck and 89 guests
