Z900 A4 fuel tank (or 1 that will fit, same shape etc)
Gray17
#1 PostAuthor: Gray17 » Tue Feb 28, 2023 12:13 pm
Wanted Z900 A4 fuel tank in good condition, not worried if its scratched etc. Pm me Price and particulars.
Re: Z900 A4 fuel tank
#2 PostAuthor: warren3200gt » Tue Feb 28, 2023 12:17 pm
What's wrong with yours Graham?
Gray17
#3 PostAuthor: Gray17 » Tue Feb 28, 2023 2:38 pm
Ha! You may well ask!, took it this morning for painting, apparently wrong one for A4 its for an LTD so striping kit wont fit, trying to get a reasonably priced one and sell mine in as its in good condition.
Its become apparent that a lot of parts have been changed for cheaper alternative, unbeknown to me as i wasnt an expert, realising now should have done more research beforehand! Argh another painful lesson learnt!
PhilMill63
#4 PostAuthor: PhilMill63 » Tue Feb 28, 2023 4:08 pm
Thats bad news, I cant imagine a tank is cheap for a decent one, are the Z Power ones any good? I may be looking if mine turns into a sieve once the internal rust is gone...
Phil
'76 Z900A4, '76 Suzuki GT750, '83 RD350 Hybrid and too many projects!
PhilMill63
#5 PostAuthor: PhilMill63 » Tue Feb 28, 2023 4:11 pm
I just saw your other post Gray, so those Z Power ones are not cheap....
Phil
Gray17
#6 PostAuthor: Gray17 » Tue Feb 28, 2023 5:35 pm
No there def not, however they are new, which in some ways is good despite price as would mean minimal prep before spraying.
I almost bought one from ebay looked decent but Warren spotted its a Z650 sprayed up to look like a Z900, even cut spike off at rear, but fueal taps a givaway oh and im told they wont fit 900 frame without mod work! Nearly got sucked in again!
Thank goodness for knowledgeable people!!!!
gray
#7 PostAuthor: gray » Tue Feb 28, 2023 6:45 pm
is it worthwhile casting your net wider to the USA. Pity Z1 Enterprises replica z900 tank in primer is out of stock
gray
Gray17
#8 PostAuthor: Gray17 » Tue Feb 28, 2023 7:23 pm
To be honest i would but its the postage cost that kills it from US and Australia and of course import duty and vat too.
dave cullen
Re: Z900 A4 fuel tank (or 1 that will fit, same shape etc)
#9 PostAuthor: dave cullen » Sun Mar 05, 2023 10:28 am
Z900A4 Z1000A1
neilbarrett
#10 PostAuthor: neilbarrett » Sun Mar 05, 2023 12:33 pm
Looks alright
#11 PostAuthor: warren3200gt » Sun Mar 05, 2023 1:03 pm
neilbarrett wrote:Looks alright
dave cullen wrote:https://www.ebay.co.uk/itm/234907082128?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=cHcCJgiwSSq&sssrc=2349624&ssuid=L45OMBEFSFu&var=&widget_ver=artemis&media=COPY
That's the one that's Z1000a2 with the two bolt tap.
dave cullen
#12 PostAuthor: dave cullen » Sun Mar 05, 2023 2:53 pm
Never noticed that, same tank tho isn't it? At least I think the repro 900 and 1000 ones are the same. Get rid of the vacuum tap ASAP!
Z900A4 Z1000A1
Kev1R
#13 PostAuthor: Kev1R » Sun Mar 05, 2023 3:06 pm
Doubtless there are some who have never had any issues with a vacuum tap but I had some problems with mine letting by on my A2 - even after I had a go with a refurb kit,
I acquired an adapter (Pingel) and a used (on off res) A1 style tap from John Browse - Problem sorted
010
Gray17
#14 PostAuthor: Gray17 » Sun Mar 05, 2023 3:58 pm
Someone else mentioned the pingel adaptor plate but when i had a look at it it has the 2 holes which bolt to the tank and a central hole with a thread, however the correct taps have a large nut which bolts onto the ptotruding same size thread from the tank. How does this adaptor plate work as the the hole diesnt look big enough and you need the protruding thread to mate to the tap, unless theres another adaptor that goes into the pingel and then enlarges to the tap size?
Unless im looking at it wrong. My other concern was the single tap outlet as mine has twin 1 for each pair of carbs, suppose you could use a Y piece but wouldnt look right, and the taps look completely different too depends how authentic you want it. If i go down thos route may as well keem my LTD and have it painted similar, apparently the decals can be made to fit, but again it will never be right.
gray
#15 PostAuthor: gray » Sun Mar 05, 2023 8:35 pm
it'll always annoy you. Wait for the right thing and then you're happy. What about France, Dutch or German ebay?
gray
