Z1000st Rear master cylinder repair kit
Mrglee
#1 PostAuthor: Mrglee » Wed Feb 15, 2023 8:20 am
Got all the brake parts I need but can't find a seal/repair kit for the rear master if no longer available what are my options?
LTD Project
Re: Z1000st Rear master cylinder repair kit
#2 PostAuthor: LTD Project » Wed Feb 15, 2023 11:18 am
you can still get a new piston, rubber seals and spring from CMSNL, so I guess z-power should be able to get them too.
KZ1000 B4 under light restoration.
moizeau
#3 PostAuthor: moizeau » Wed Feb 15, 2023 3:40 pm
Have you tried this place
https://powerhouse.uk/motorcycle-brake- ... t-service/
Very recommended
#4 PostAuthor: Philippe » Wed Feb 15, 2023 4:45 pm
Hi Mrglee
have look at this:
https://www.z-power.co.uk/z1000e1e2-st/ ... r-cylinder
these are original Kawasaki parts.
There's a pattern replacement available too.
Mrglee
#5 PostAuthor: Mrglee » Wed Feb 22, 2023 3:42 pm
Cheers guys but z-power only have kits for the E1 with resivor built into master model mines a e2 which has a separate resivor connected by a short hose nobody seems to have one anymore.
So any suggestions on how to get round this problem would really be appreciated.
moizeau
#6 PostAuthor: moizeau » Wed Feb 22, 2023 4:24 pm
Did you contact Powerhouse?
Mrglee
#7 PostAuthor: Mrglee » Thu Feb 23, 2023 4:39 pm
Yes I did but they don't have them either from what I understand the master cylinder (43020-1015) was only fitted for a very limited time but have found two places one in America £100 and Australia on eBay for £50 that can supply the two rubber seals.
LTD Project
#8 PostAuthor: LTD Project » Mon Feb 27, 2023 12:05 pm
https://www.cmsnl.com/kawasaki-kz1000e2 ... 66560.html
Which part numbers are you referring to?
#9 PostAuthor: z1bman » Mon Feb 27, 2023 1:19 pm
According to csml the part no for the piston is the same as the z1000 a1 & other models so this should fit
https://www.z-power.co.uk/piston-rear-master-cylinder
Mrglee
#10 PostAuthor: Mrglee » Mon Feb 27, 2023 7:48 pm
Have already been advised this will not fit here's a pic of mine
