Z1 Rear axle sleeve
wilsonsjw11
Z1 Rear axle sleeve
#1 PostAuthor: wilsonsjw11 » Fri Jun 17, 2022 5:10 pm
Could someone please advise me of the thickness of the different rear axle sleeves for a Z1/Z1B(43027-020 and 42037-023)
Regards
Steve
steve452
Re: Z1 Rear axle sleeve
#2 PostAuthor: steve452 » Sat Jun 18, 2022 11:10 am
From what I can see 42037-023 superceded 42037-020 from frame no. Z1F02000 (I assume that your ref. to 43027-020 was a typo as it doesn't exist as a part number).
As there appears to be only one axle used then the ID should remain the same. IIRC the collar (what Kawasaki call it) fits inside the sprocket carrier bearing (601B6-206) and there is only one listed so the OD should be the same thoughout.
Apologies if this is not what you were after.
Source: John Brookes most excellent Restorers Parts Book (6th edition.
Z1-B, 360bhp ZX1000NGF
z2.john
#3 PostAuthor: z2.john » Sat Jun 18, 2022 12:21 pm
Ø20.1 x Ø40 x 11 thk
wilsonsjw11
#4 PostAuthor: wilsonsjw11 » Sat Jun 18, 2022 2:45 pm
John,
You are correct, it’s a typo.
That is the info I was after and I assume the superseded part is thicker for use with the O ring chain because with the slimmer item fitted the chain comes within 2-3mm of the rear sprocket securing bolts.
Regards
Steve
