Throat boring Vm26 questions
#1 PostAuthor: warren3200gt » Tue May 31, 2022 8:53 am
How far can you safely throat bore vm 26's and what is best to do about needle valve seats?
Re: Throat boring Vm26 questions
#2 PostAuthor: Ultim8pc » Tue May 31, 2022 9:26 am
warren3200gt wrote:How far can you safely throat bore vm 26's and what is best to do about needle valve seats?
I've seen quite a few sets of bored out carbs. On some the needle valve was trimmed (lowered) and on others it wasn't...
#3 PostAuthor: warren3200gt » Tue May 31, 2022 9:56 am
Do you know what dia they were bored to ?
#4 PostAuthor: zed1015 » Tue May 31, 2022 9:57 am
I've done this a few times.
You can safely go to 29.5mm and depending on the thickness of the casting in the boot groove area up to 30mm.
All the details start at the bottom of page 15 through to 19 in my cafe racer project thread.
viewtopic.php?f=7&t=14312&start=210
#5 PostAuthor: warren3200gt » Tue May 31, 2022 11:18 am
Perfect ta Rob. Safe upto 29mm then. :up
#6 PostAuthor: Z1streetfighter71 » Tue May 31, 2022 12:14 pm
Have you ever considered taking on a set for some one else.. 2 sets even... hint hint wink wink
#7 PostAuthor: warren3200gt » Tue May 31, 2022 12:24 pm
For your sake, I hope your asking Rob and not me!
#8 PostAuthor: warren3200gt » Tue May 31, 2022 12:42 pm
Rob, have you done a set that had both fuel and air screws? Just wondering how much taper there is on the fuel screw carb body? Bit worried about boring it which might increase the hole diameter.
#9 PostAuthor: zed1015 » Tue May 31, 2022 12:49 pm
warren3200gt wrote:Rob, have you done a set that had both fuel and air screws? Just wondering how much taper there is on the fuel screw carb body? Bit worried about boring it which might increase the hole diameter.
Yes! The ones i did for the alloy cafe were Suzuki GS750 VM26MM carbs which have both.
No problems.
#10 PostAuthor: warren3200gt » Tue May 31, 2022 1:13 pm
Top man. :up
#11 PostAuthor: Z1streetfighter71 » Tue May 31, 2022 1:21 pm
warren3200gt wrote:For your sake, I hope your asking Rob and not me!
Ha yes was asking Rob but im sure you do good work too... :D
#12 PostAuthor: kev edwards » Tue May 31, 2022 7:04 pm
If you have a lathe it should be easy enough.
#13 PostAuthor: warren3200gt » Tue May 31, 2022 7:12 pm
I'm not convinced that I have enough chuck center line to bed clearance to accommodate the slide body Kev. Need to have a measure up before stripping them down.
#14 PostAuthor: Z1streetfighter71 » Tue Oct 11, 2022 8:27 pm
Sorry for resurrecting this thread but the question of the needle valve seats, Rob- did you remove them or bore them out?
#15 PostAuthor: zed1015 » Tue Oct 11, 2022 9:01 pm
Z1streetfighter71 wrote:Sorry for resurrecting this thread but the question of the needle valve seats, Rob- did you remove them or bore them out?
What do you mean by needle valve seats ?
Users browsing this forum: Google [Bot] and 84 guests
