Z650 refresh...
Re: Z650 refresh...
With a tee piece to connect the turbo oil tank and crankcase top breather lines.
Z650/1100 turbo, GPz750 rolling resto, Z650 restomod
Re: Z650 refresh...
The rear brake's clear brake line hose had gone really manky, despite it apparently being pukka Hodna HRC stuff, and it's leaked some fluid out onto the master cylinder, so it was all taken off, cleaned up, repainted and fitted with some properly pukka 2375 Tygon that is allegedly impervious to brake fluid. We'll see about that eh.
Re: Z650 refresh...
Finally got sorted with a pair of cables to suit the throttle assembly and Mikuni carb, thanks to Carrot Cycles in Lincoln.
