Cylinder head Washers
Skid Mark
#1 PostAuthor: Skid Mark » Wed Jan 19, 2022 9:36 pm
Hi All,
Can anyone advise on the correct code and quantity, for the copper washers on the head of a 1000R?
I took off 4 copper and 8 steel washers, this appears to tie in with the parts manual which shows 4 nr. part. 92022-1005 and 8nr. 411B1000, however when I enter these codes on both Zpower and CMS, I get no results. Zpower do have a set of 12 washers, (different code), is there any harm replacing all 12 with copper?
Thanks in advance!
Skid Mark
Re: Cylinder head Washers
#2 PostAuthor: Skid Mark » Wed Jan 19, 2022 9:47 pm
Oops!,
I managed to find them on CMS, Had the search set to part name, don't know why I can't find them on Zpower though. :blush
any reason not to use copper on all 12 bolts??
#3 PostAuthor: zed1015 » Wed Jan 19, 2022 10:03 pm
No problem using all copper.
I do.
When you buy them new it's a good idea to anneal them ( heat cherry and quench in water to flash off the oxides) as they come work hardened from the stamping process.
Skid Mark
#4 PostAuthor: Skid Mark » Wed Jan 19, 2022 10:14 pm
Noted!
Thanks for the reply!
Users browsing this forum: No registered users and 73 guests
