Brass Tube
Wayne1960
Brass Tube
#1 PostAuthor: Wayne1960 » Sun Sep 27, 2020 2:00 pm
I am looking for the brass tube that fits at the base of the carb Mikuni VM26ss
I think it's the pick up pick up for the choke.
I notice one of mine being a good 6mm shorter than the rest
With the float bowl off its the fixed tube sits about 30mm above the body and has small airways.
I think it simply pushes in so it should pull out if anyone can help?
Bike now finished what a joy!
Keefleaf
Re: Brass Tube
#2 PostAuthor: Keefleaf » Sun Sep 27, 2020 5:28 pm
You can buy it on Enay.
Keefleaf
Re: Brass Tube
#3 PostAuthor: Keefleaf » Sun Sep 27, 2020 5:29 pm
EBay :rock
Wayne1960
Re: Brass Tube
#4 PostAuthor: Wayne1960 » Sun Sep 27, 2020 7:14 pm
Ok great what should I search for?
Re: Brass Tube
#5 PostAuthor: kev edwards » Mon Sep 28, 2020 7:03 am
Just type in brass tube, isn't there a jet pressed into the bottom of the tube as well, type in brass tube of the right diameter you will need the inside diameter as well, send me the outside measurement, if it is the same as the overflow tube i have some as i made overflows to replace broken ones.
https://www.ebay.co.uk/itm/Top-Brass-Tu ... 54152e0cf5
https://www.ebay.co.uk/itm/Brass-Tube-P ... SwTfdbM2yA
Re: Brass Tube
#6 PostAuthor: Pigford » Mon Sep 28, 2020 9:48 am
The brass tubes have been known to split causing problems.
An easier repair option may be to locate a small diameter plastic pipe and slide that over the brass tube?
KeithZ1R
Re: Brass Tube
#7 PostAuthor: KeithZ1R » Mon Sep 28, 2020 11:53 am
I have had success soldering cracks in the brass tubes cleanliness is the key
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
Re: Brass Tube
#8 PostAuthor: zed1015 » Mon Sep 28, 2020 12:06 pm
The tube isn't broke it's just shorter than the rest.
He needs a stock length one around 30mm.
Wayne1960
Re: Brass Tube
#9 PostAuthor: Wayne1960 » Mon Sep 28, 2020 3:06 pm
Hi Kev
The tube has very small holes in it so not just a tube.
Users browsing this forum: Bing [Bot] and 33 guests
