Oil filter drain plug
jonhunt
#1 PostAuthor: jonhunt » Wed Mar 25, 2020 10:43 am
The oil filter drain plug on my Z1A is damaged. I’m going to replace it. From memory I don’t think there’s a washer or o ring under it. Should there be?
Re: Oil filter drain plug
#2 PostAuthor: Pigford » Wed Mar 25, 2020 10:44 am
Hi Jon, I'm not sure, just saying hello :D but I thought it should have an alloy washer :?:
Gus
#3 PostAuthor: Gus » Wed Mar 25, 2020 10:48 am
"Set the GRINDER on it"
Mr Bump
#4 PostAuthor: Mr Bump » Wed Mar 25, 2020 11:17 am
Not the oem solution, but I use dowty sealed washers on all sump plugs, car or bike.
A better solution IMO if you can get them and reusable without annealing (I generally aquire them from work).
Olly
Lemmy
#5 PostAuthor: Pigford » Wed Mar 25, 2020 11:20 am
Gus - item #20 :wink:
Mr Bump - can you anneal a Dowty washer - thought they has rubber seal built in?
Gus
#6 PostAuthor: Gus » Wed Mar 25, 2020 11:23 am
Pigford wrote:Gus - item #20 :wink:
Hi Mark.
Are you well?
I just went by what John asked for. The "oil filter drain bolt" not the "sump drain bolt". :lol:
Gus
#7 PostAuthor: Pigford » Wed Mar 25, 2020 11:25 am
Hi Mark.
Are you well?
Gus
Hi matey - ah yes, I (as usual) didn't read it properly!
Mr Bump
#8 PostAuthor: Mr Bump » Wed Mar 25, 2020 11:51 am
....what I meant was you might have to anneal or replace a copper washer or replace an ally washer, but because the dowty washers are rubber sealed they are reusable without any messing about.
Olly
Lemmy
#9 PostAuthor: Pigford » Wed Mar 25, 2020 2:38 pm
Olly
:up
