Chain Length
walshyco
Chain Length
#1 PostAuthor: walshyco » Mon Aug 19, 2019 9:20 am
Can anyone confirm please the chain I need to order for a Z1000 ltd 78, front sprocket is 15T and rear is 33T, I thought it should be 630 92L, but M&P say that is incorrect but they don't say what it should be.TIA. Sean .
Re: Chain Length
#2 PostAuthor: ZedHead » Mon Aug 19, 2019 10:10 am
walshyco wrote:Can anyone confirm please the chain I need to order for a Z1000 ltd 78, front sprocket is 15T and rear is 33T, I thought it should be 630 92L, but M&P say that is incorrect but they don't say what it should be.TIA. Sean .
92 is correct. However LTD used a 35 rear as standard. You might get away with 90, although It is easier to remove a couple of links if needs be.
walshyco
Re: Chain Length
#3 PostAuthor: walshyco » Mon Aug 19, 2019 2:21 pm
Thanks Dave, its an endless chain I want so wanted to be sure, this bike has got a standard Z1000 rear wheel fitted so that explains the 33t rear. I will give you a call in the next few days . Thanks. Sean.
