Gpz1100b1 Grab rail
scott
Junior Section leader
Gpz1100b1 Grab rail
#1 PostAuthor: scott » Mon Jan 21, 2019 9:14 pm
My grab rail has a long stem on the right hand side and a short stem on the left hand side. The right hand side mates perfectly to the frame mount. The left hand side does not reach the frame mount. Looks like a space of about 15mm...approximately. Does some sort of spacer live here normally?
Re: Gpz1100b1 Grab rail
#2 PostAuthor: Al » Mon Jan 21, 2019 9:56 pm
The helmet lock has a tubular spacer fixed to it of that approximate size.
scott
#3 PostAuthor: scott » Mon Jan 21, 2019 10:11 pm
Thanks Al, I’ll try and find some pictures of a seat lock and how it’s fitted.
sockpuppet
#4 PostAuthor: sockpuppet » Mon Jan 21, 2019 10:12 pm
Hi Scott
As AL says the grab rail mounting bolt on the left side passes through the seat catch/ helmet lock .
Mick
#5 PostAuthor: Al » Mon Jan 21, 2019 10:21 pm
https://www.cmsnl.com/kawasaki-kz1000j1 ... 62046.html
27016A Shows the seat catch / helmet lock with the spacer attached.
You could just make a tubular spacer if you dont need the catch.
scott
#6 PostAuthor: scott » Tue Jan 22, 2019 7:20 am
Thanks, appreciated.
scott
#7 PostAuthor: scott » Tue Jan 22, 2019 7:41 am
27016 5069 seems to be unavailable.....any ideas where to get one?
#8 PostAuthor: chrisNI » Tue Jan 22, 2019 8:39 am
These are quite hard to find unfortunately... 1000r, 1100R and some 550s use the same lock
scott
#9 PostAuthor: scott » Tue Jan 22, 2019 9:31 am
Thanks, i'll look forward to the search :lol:
#10 PostAuthor: Al » Tue Jan 22, 2019 8:09 pm
scott
#11 PostAuthor: scott » Tue Jan 22, 2019 8:12 pm
Works out about £50 from the states, maybe worth a punt. I think it says that it has no keys. Can I replace the barrel for one with a key?
#12 PostAuthor: Al » Tue Jan 22, 2019 8:16 pm
Second one above looks cheaper and you can get a key cut using the stamped number on it.
EDIT SECOND ONE (GPZ 550) IS A RED HERRING SORRY.
#13 PostAuthor: Al » Tue Jan 22, 2019 8:30 pm
https://www.ebay.co.uk/itm/Seat-Lock-Me ... :rk:1:pf:0
Looks like Tomforde does a no key replacement part might be B2 only!!!!!!!
scott
#14 PostAuthor: scott » Tue Jan 22, 2019 8:43 pm
Ok, at least I know I can fall back on the Tomforde one if necessary.
Taffus
#15 PostAuthor: Taffus » Wed Jan 23, 2019 8:13 pm
Scott I must have it here! let me look before you spend out
