SOLD z1000a1 swinging arm
Advertise your BIKES and PARTS here
8 Valve Mark
#1 PostAuthor: 8 Valve Mark » Sat Jan 05, 2019 11:10 am
newly powder coated in gloss black, with chain adjuster blocks too, new bearings, n new axle sleeve £120.00 delivered to uk address.pm for anymore info or photos. cheers mark
8 Valve Mark
Re: z1000a1 swinging arm
#2 PostAuthor: 8 Valve Mark » Sun Jan 13, 2019 1:21 am
bump! reduced to £110.00 cheaper than the the sum of the parts n work involved.. m
u648216
#3 PostAuthor: u648216 » Thu Jan 24, 2019 12:00 pm
Hi . new to this forum...Im interested in the swinging arm. my bike is a 1978 z1000 but has the old type bearing arrangement with solid bushes/bearing and not needle bearing. does yr arm come with the swing arm spindle and if so could you let me know it diameter . many thanks Rob.
have attached a piccy out of the haynes manual showing what it looks like
8 Valve Mark
#4 PostAuthor: 8 Valve Mark » Thu Jan 24, 2019 1:50 pm
that's a z1-z900 swing arm for rear drum brake rob! has your bike been modified? the standard spindle is 16mm, i might have a spare one.
u648216
#5 PostAuthor: u648216 » Sun Jan 27, 2019 1:41 pm
Hi. Dont know the history but it has been modified in places. I thought it was off an older bike. The spindle I have is 16mm tho worn. it is running a rear disc.
8 Valve Mark
#6 PostAuthor: 8 Valve Mark » Sun Jan 27, 2019 1:53 pm
i have a spare spindle you can have. pm if interested. cheers m
#7 PostAuthor: zed1015 » Sun Jan 27, 2019 2:27 pm
u648216 wrote:Hi. Dont know the history but it has been modified in places. I thought it was off an older bike. The spindle I have is 16mm tho worn. it is running a rear disc.
All the spindles on the chain drive 900/1015 motor bike are "16"mm.
Are you sure yours is worn as they are actually undersize at 15.8mm and the frame oversize at 16.2mm resulting in a bit of a loose fit.
Return to “For Sale”
