Camshaft degeeing
chrisw1
Camshaft degeeing
#1 PostAuthor: chrisw1 » Fri Nov 30, 2018 9:17 pm
Hello ...can anyone point me in the direction of a step by step guide to degreeing in camshafts on a Z1 please
Re: Camshaft degeeing
#2 PostAuthor: Ginger Bear » Fri Nov 30, 2018 9:38 pm
One of the easiest (for me) set of instructions to follow came from Joe Hooper. I'll see if I can find them and scan them for you.
# 104
#3 PostAuthor: Pigford » Sat Dec 01, 2018 9:07 am
Just take it steady - needs alternator cover off too!
#4 PostAuthor: zed1015 » Sat Dec 01, 2018 4:08 pm
Plenty of "how to tutorials" on the net if you do a google search.
Some are more clearer than others.
Here's a couple that should be clear enough.
https://sites.google.com/site/suzukitec ... -camshafts
http://www.webcamshafts.com/mobile/degreeing.html
chrisw1
#5 PostAuthor: chrisw1 » Sat Dec 01, 2018 5:21 pm
Thanks for that ..all very interesting and I think i will be able to do it
Just one question ..... in the first magazine article they say set the valve clearances and in the 2 links they say remove all valve lash ...... do they mean excess lash or set the valve clearance to zero ?
#6 PostAuthor: zed1015 » Sat Dec 01, 2018 7:34 pm
chrisw1 wrote:Thanks for that ..all very interesting and I think i will be able to do it
You can use whatever lash you want or even negative clearance, the maths will always give the same results .
I set the clearance at what the engine will be run at.
When done you want to run 0.15mm .
chrisw1
#7 PostAuthor: chrisw1 » Sat Dec 01, 2018 7:59 pm
Thanks again ..ok Im up to speed ...just need my pistons to arrive and i will get stuck in :)
Users browsing this forum: No registered users and 103 guests
