Rear shocks
scott
Junior Section leader
Rear shocks
#1 PostAuthor: scott » Wed Nov 28, 2018 1:27 pm
Would anyone know if ZRX1100 rear shocks will fit a Gpz1100b1. Same length??
I was thinking of buying these if they will fit:
https://www.ebay.co.uk/itm/Ohlins-pair- ... Blackline-Hodna-CB1300-/11283038546
Apparently Ohlins HO963, as listed above, fits various bikes including CB1300 and ZRX1100
Big Fluff
Re: Rear shocks
#2 PostAuthor: Big Fluff » Wed Nov 28, 2018 3:12 pm
GONE !
scott
Re: Rear shocks
#3 PostAuthor: scott » Wed Nov 28, 2018 3:20 pm
That does not answer the question though
Charlie
Re: Rear shocks
#4 PostAuthor: Charlie » Wed Nov 28, 2018 3:50 pm
ZRX shocks are 365mm centres. 12mm eye at the top, 10mm eye at the bottom. Reservoir goes to the top
ZRX1200 shox have a plastic cover inside the shock body, 1100 don't. That aside, they are pretty much the same items
The shocks will fit pretty much any Zed - it would only be the length that altered. They fit my modified Z650 OK but are longer (in my case that isn't an issue)
I have no idea how long GPZ shocks though
scott
Re: Rear shocks
#5 PostAuthor: scott » Wed Nov 28, 2018 4:23 pm
Thank you kindly sir
Re: Rear shocks
#6 PostAuthor: ZedHead » Thu Nov 29, 2018 7:17 pm
https://www.saisei-europe.com/Shop/Prod ... oad-track2
I sold these to Lee Jackson a couple of years ago to fit on his ELR project. If I remember correctly he used a ZRX swing arm.
Ohlins do not list anything for GPZ1100 B1 but I would guess they would fit.
If you want further clarification I would be happy to ask my technical contact at Ohlins on your behalf
scott
Re: Rear shocks
#7 PostAuthor: scott » Thu Nov 29, 2018 9:46 pm
I’m sure I’ll be able to wrestle them on somehow. :lol:
scott
Re: Rear shocks
#8 PostAuthor: scott » Thu Nov 29, 2018 9:47 pm
Thanks saisei. Didn’t realise you sold them.
Re: Rear shocks
#9 PostAuthor: Al » Thu Nov 29, 2018 10:30 pm
1981 J1 shocks are 350mm (347 to be picky) centre eye to centre eye.
There is a slight peculiarity with the J1 shocks. Its bottom eye is spaced to one side and its supposed to be like it.
It is to clear the 630 chain and chainguard.
It may be possible that the above also applies to the 1981 B1, however if you are changing the swingarm then it all becomes academic.
Re: Rear shocks
#10 PostAuthor: ZedHead » Fri Nov 30, 2018 8:13 am
scott wrote:Thanks saisei. Didn’t realise you sold them.
Your welcome Scott. I have been an Ohlins dealer for nearly 5 years. Information is free :D
ogre
Re: Rear shocks
#11 PostAuthor: ogre » Fri Nov 30, 2018 2:46 pm
here you go scott zrx shocks on my b2 but i had to alter chain guard a smidge.
scott
Re: Rear shocks
#12 PostAuthor: scott » Fri Nov 30, 2018 3:23 pm
Very nice bike mate
Big Fluff
Re: Rear shocks
#13 PostAuthor: Big Fluff » Mon Dec 03, 2018 1:16 pm
Scott. If you end up buying a set and needs some new KYB decals then let me know as I sell these in either red or gold.
https://www.ebay.co.uk/itm/KAWASAKI-ZRX ... :rk:2:pf:0
Regards Will
Users browsing this forum: No registered users and 105 guests
