Z1R-TC
Advertise your BIKES and PARTS here
Big Fluff
Z1R-TC
#1 PostAuthor: Big Fluff » Mon Oct 08, 2018 8:13 am
A friend of mine has decided to sell some of his toys, including this TC that I've just spent 100 hours on for him.
It was originally from Canada but I've fitted a UK spec speedometer to suit.
New paint, including all black chassis parts, the only thing it needs are some of the fasteners need replating (all original).
Just done a full engine build for him. Working from the bottom up, spec as follows:
Fully welded crank, APE crank studs, anti-surge plate, sump baffle mod, NEW 1075cc MTC forged pistons & rings, teflon buttons, 3-layer spring steel head gasket, APE cyl studs & nuts, APE stem seals, APE H/D valve springs, Mikuni HSR42 carb conversion, polished stainless matrix deep air filter, dual crankcase breather mod, Dyna 2000 ignition system, Dyna mini coils, Dyna silicone leads, boost activated retard kit, complete Rajay turbo overhaul, extended turbo oil feed line mod, wastegate spring mod kit fitted, new OE boost hoses, Z1000H rear shocks fitted (couldn't find any genuine dual spring Z1R), kick start present under seat, complete rebuild with all new parts on both master cylinders, new brake cable, new fuel tap, new engine screw kit, all new cables, new grips, loads more.............
There’s a 56 page illustrated rebuild manual and parts breakdown to go with the bike too, along with a few spares.
Observing the current market, he’s looking for around £26k for this example which has had all the work done.
Contact Steve Mead on 07798 586931
zapo
Re: Z1R-TC
#2 PostAuthor: zapo » Mon Oct 08, 2018 11:59 am
Very nice.
If anybody out there would like to buy one of my kidneys for 26k please get in touch :D
I see Zed people.
DavidZ1R
Re: Z1R-TC
#3 PostAuthor: DavidZ1R » Mon Oct 08, 2018 6:37 pm
Hi Will, sorry for the long delay, but that cover you wanted is due In next week, looking at the great pics you don't need it ?
Big Fluff
Re: Z1R-TC
#4 PostAuthor: Big Fluff » Mon Oct 08, 2018 7:51 pm
Not really, not now the bike's gone back to the customer. All the best Will
Return to “For Sale”
