Carb Repair
Carb Repair
Any advice on the best place to get carb repair kits 4 a Z1 please , thanks in advance
Re: Carb Repair
Hi marmck
try Z-Power in the UK or Z-Fever in Germany or Classickawaparts in Holland... the choice is up to you, when ordering make sure you ask the correct set and that the correct carbs are on your Z1. The original Z1 carbs were in the past often replaced by those of the Z900A4...
Re: Carb Repair
DavidZ1R wrote:Nrp carbs, Manchester, best sets.
+1 for NRP
Re: Carb Repair
no Z1 900 carb bits on NRP web site plenty of Z1000 , Defo Z1 900 carbs Phllippe , Big nuts on float bowls , will try other suggested sites thanks for the replys , Martin
Re: Carb Repair
Vapourworx Ben there has loads of parts in stock and available. He done a full resto on my carbs.
Re: Carb Repair
marmck wrote:no Z1 900 carb bits on NRP web site
Drop them an email.
I needed needles for a 82 Z400J, not a bike that appears on their site, but I got sorted after sending them an email.
2006 ZRX1200R
1982 Z400J project
ex owner of Z1100R
GXI 2752 are you out there?
1982 Z400J project
ex owner of Z1100R
Re: Carb Repair
Anyone used these - https://www.z1enterprises.com/carbureto ... 73-76.html
