Indicators
AlanB
Indicators
#1 PostAuthor: AlanB » Thu Apr 05, 2018 5:29 pm
Noticed that when the headlight on my Z1000 is on the indicators flash more slowly - Checked battery on multi-meter when removed from bike and shows over 12v to fully charged - Should I check battery with engine running - Any thoughts ? Cheers all. :roll:
Re: Indicators
#2 PostAuthor: Pigford » Thu Apr 05, 2018 5:58 pm
Most likely poor wiring - aged wires & connectors!
Re: Indicators
#3 PostAuthor: Garry.L » Thu Apr 05, 2018 6:03 pm
AlanB wrote:Noticed that when the headlight on my Z1000 is on the indicators flash more slowly - Checked battery on multi-meter when removed from bike and shows over 12v to fully charged - Should I check battery with engine running - Any thoughts ? Cheers all. :roll:
Did you check the voltage with the engine running?.
AlanB
Re: Indicators
#4 PostAuthor: AlanB » Thu Apr 05, 2018 6:24 pm
thanks guys - If I test battery with engine running, what am I looking for and what would it mean ? cheers
Re: Indicators
#5 PostAuthor: chrisu » Thu Apr 05, 2018 6:44 pm
should be 13.8-14.5 running
AlanB
Re: Indicators
#6 PostAuthor: AlanB » Thu Apr 05, 2018 7:16 pm
Ahh great thanks - If it's not, what would that suggest the problem is ?
Re: Indicators
#7 PostAuthor: Garry.L » Thu Apr 05, 2018 7:47 pm
AlanB wrote:Ahh great thanks - If it's not, what would that suggest the problem is ?
Probably the Regulator/Rectifier, more so if it's the original one/s.
See the sticky at the top of this section on how to test.
AlanB
Re: Indicators
#8 PostAuthor: AlanB » Thu Apr 05, 2018 7:51 pm
Thanks - Had a new combined reg/rec 18 months ago and prob done 200 miles since - I'll check anyway - Cheers all.
albrob
Re: Indicators
#9 PostAuthor: albrob » Fri Apr 06, 2018 8:58 am
I had the same problem on my LC turned out to be the flasher relay!
