New Chain & Sprockets
alfacity
#1 PostAuthor: alfacity » Sat Sep 23, 2017 5:13 pm
Looking to buy new chain and sprockets for my Z900 A4, which is the best make to buy?
Z1A & Z1000R2 ELR
floydsz1
Re: New Chain & Sprockets
#2 PostAuthor: floydsz1 » Sat Sep 23, 2017 5:57 pm
Don't think it matters as long as it's a well known brand, I went for a 530 conversion from debbens performance
Z1b,
zxr750 m2,
zrx1200
Z1000j lawson race bike,
Versys 1000gt (2019),
alfacity
#3 PostAuthor: alfacity » Sat Sep 30, 2017 2:43 pm
Thanks I’ll do the same. Did you keep the original swing arm?
Z1A & Z1000R2 ELR
Garn 1
#4 PostAuthor: Garn 1 » Wed Oct 04, 2017 8:06 am
Alfacity, as Floydez1 suggests, 530 chain is the way to go, withy equivalent sprocket.
#5 PostAuthor: chrisu » Wed Oct 04, 2017 11:55 am
alfacity wrote:Thanks I’ll do the same. Did you keep the original swing arm?
no change other than sprockets and depending the bike maybe a spacer. it'll be in the bike specific kit.
check Debben, Zpower and Saisei to compare prices - all do them i think. I got mine from Saisei
Fred the Zed
#6 PostAuthor: Fred the Zed » Wed Oct 04, 2017 4:23 pm
floydsz1 wrote:Don't think it matters as long as it's a well known brand, I went for a 530 conversion from debbens performance
+1
Fred
Paid Up Member
#7 PostAuthor: ZedHead » Wed Oct 04, 2017 5:18 pm
To convert to 530 just multiply original teeth and chain links by 1.2 and go for the nearest
So for Z900....
Front 15T x 1.2 = 18T
Rear 33T x 1.2 = 39.6T
Chain 92 x 1.2 = 110.4
Experience has shown that a 40T rear and 110 chain is a bit tight so 112 works better. It is easier to remove a couple of links later if it wont adjust up.
There are loads of good heavy duty x ring chains about these days.
Taffus
#8 PostAuthor: Taffus » Wed Oct 04, 2017 5:40 pm
ZedHead wrote:To convert to 530 just multiply original teeth and chain links by 1.2 and go for the nearest
So for Z900....
Do you do kits Dave?
#9 PostAuthor: ZedHead » Wed Oct 04, 2017 6:23 pm
Yes but I am waiting for the special rear sprockets
Garn 1
#10 PostAuthor: Garn 1 » Wed Oct 04, 2017 11:12 pm
You may find a slight problem... That is on the front sprocket (18t) there is often, no locking washer hole, You may have to fashion something to lock the sprocket. There is two threaded holes on some front sprockets, it just requires a bit of sheet metal work to make the lock washer.
#11 PostAuthor: ZedHead » Thu Oct 05, 2017 8:14 am
Garn 1 wrote:You may find a slight problem... That is on the front sprocket (18t) there is often, no locking washer hole, You may have to fashion something to lock the sprocket. There is two threaded holes on some front sprockets, it just requires a bit of sheet metal work to make the lock washer.
This used to be a problem however PMC make the correct front sprockets now. 530 Rear sprockets for 77 on wards are freely available however Z1 - Z900 are a special.
Before anyone jumps on their "High horse" this is information and not a sales pitch. You know who you are :roll:
PaulMceleney
Chunks
#12 PostAuthor: PaulMceleney » Mon Oct 09, 2017 9:24 pm
How much is the 530 chain and sprocket kit I have 17inch wheels on my
#13 PostAuthor: ZedHead » Tue Oct 10, 2017 7:15 pm
paulmceleney wrote:How much is the 530 chain and sprocket kit I have 17inch wheels on my
PM sent
