Replacement fuel tap.
timyoungman
#1 PostAuthor: timyoungman » Thu Mar 16, 2017 4:17 pm
Can anyone advise on a good gravity fed replacement fuel tap. Not pingel as they are too expensive. I am looking for aftermarket tap with 44mm centres for z650. Any ideas? Thx
Re: Replacement fuel tap.
#2 PostAuthor: ADRIAN H » Thu Mar 16, 2017 9:26 pm
Sorry, but I don't know of any other than Pingel.
trikerdrew
#3 PostAuthor: trikerdrew » Thu Mar 16, 2017 10:28 pm
Service the one you got?
If you need higher flow and don't need reserve solder pipe into alloy boss to fit same centres as z650
Good luck
Drew
timyoungman
#4 PostAuthor: timyoungman » Fri Mar 17, 2017 4:55 pm
Thanks for the replies. Apparentky gpz900 fuel tap has 44mm fittings, so i am going to try one from flee bay :D
johnA
#5 PostAuthor: johnA » Sun Mar 19, 2017 7:53 pm
tour max taps are good quality as good as oe at least.
Users browsing this forum: No registered users and 121 guests
