ZRX 1100 swing arm in a Z1000A frame
Hi,
I'm fitting a ZRX swingarm in my Z1000 and am wondering which is best, reem the frame for a ZRX spindle or change bearings to take a Z1000 spindle?
Anyone know where I can get a stainless or titanium example of either spindle as well?
Russ
Russ
LeeJackson
LeeJackson
Unless you already bought the swinger, it'd be better to get hold of a ZRX1200 swingarm. The 1100 took a 170 profile rear tyre which are limited in choice. The ZRX12 used a wider wheel and took a 180 rear tyre. The wheels wont interchange without a chunk of work either .....
Charlie wrote:Unless you already bought the swinger, it'd be better to get hold of a ZRX1200 swingarm. The 1100 took a 170 profile rear tyre which are limited in choice. The ZRX12 used a wider wheel and took a 180 rear tyre. The wheels wont interchange without a chunk of work either .....
zxr750 h1/2 wheels go straight in,5.5 inch for 180 tyre
Zrx 1200 wheel goes into the 1100 swinging arm, all I did was turn a spacer around and machine the rear brake The hanger is made out of tough metal, so you will need a good tool in the lathe. Look at the zrx owners site, they have all the details needed.
Rob
Rob
My frames away at the moment having the top shock mounts relocated and a zrx1100 swingarm fitted by Rob. He makes race frames for a living and came highly recommended. I mentioned using top hat spacers so no reaming of the frame. He was not happy at that so I told him to do whatever he thought best. Will post pictures when I get it back.
PUM 13
