GPz1100 Odometer
MikeP
GPz1100 Odometer
#1 PostAuthor: MikeP » Fri Mar 04, 2016 2:41 pm
Just bought a GPz1100B1 from Italy and as usual it's in KMH.
The speedo can be converted with a new overlay to show MPH, and with odometer being separate, I've bought a secondhand odometer with Miles to suit.
My question is: how do I adjust the odometer to show the corrected Miles as a conversion from Kilometers? Any ideas?
Yellow
#2 PostAuthor: Yellow » Fri Mar 04, 2016 7:13 pm
Put a drill with reverse action and a piece of old speedo cable. Calculation is Kilometres divided by 8 multiplied by 5 equals miles.
May take a while.....
Taffus
#3 PostAuthor: Taffus » Fri Mar 04, 2016 7:39 pm
Unfortunately this one is electronic and will only go forward with the correct waveform as an input.
The case is also very well sealed and it takes a great deal of patience to breakin without damaging it
#4 PostAuthor: PAULJAC47 » Fri Mar 04, 2016 7:40 pm
At one time u could get converters to put in line with the drive to convert kmh to mph so clock would read correctly!
Taffus
#5 PostAuthor: Taffus » Fri Mar 04, 2016 7:49 pm
This system isn't too clever, it takes a square wave and uses a an RF (radio frequency) chip to produce a dc voltage which then drives a small motor to turn the numbers.
MikeP
#6 PostAuthor: MikeP » Sat Mar 05, 2016 6:41 pm
Yeah, this isn't like the usual speedo drive from the front wheel, as Taffus says, and I may need to practice with the dremel on the old KMH odometer.
The GPz has only done 18500 kilometres so will be a good selling point if I decide to sell.
Users browsing this forum: No registered users and 96 guests
