Carb Tune
#61 PostAuthor: z1bman » Sun Sep 20, 2015 6:53 pm
i would with the trouble most people have had with them
http://www.ngk-sparkplugs.jp/english/techinfo/fake/
Wayne1960
#62 PostAuthor: Wayne1960 » Sun Sep 20, 2015 7:06 pm
ok can you recommend the absolute best ones for my bile please
Bike now finished what a joy!
#63 PostAuthor: z1bman » Sun Sep 20, 2015 7:14 pm
Wayne1960
#64 PostAuthor: Wayne1960 » Mon Sep 21, 2015 7:11 pm
Ok had a couple of hours at it today and ended up with engine running ok.
But shouldn't be!
Ticking over nicely and sounds ok.
But
Air screw on 1 turned out further than specified as was 2
3 I think was about normal
4 had to screw all the way home!!!!!!
1 and 4 running cooler than 2 and 3 but maybe that's ok as the inner pots will be hotter.
Ideas it simply doesn't make sense.
000zeds
#65 PostAuthor: 000zeds » Mon Sep 21, 2015 7:34 pm
Wayne something wrong if it runs with air screw all the way home !
Zeds-R-Us
#66 PostAuthor: z1bman » Mon Sep 21, 2015 7:48 pm
make sure the air jet & pilot jet are clear spray some wd 40 in to the jets while they are still fitted to the carbs it should drain out under the slide there is a tiny hole in the carb where you check the slide height .
Wayne1960
#67 PostAuthor: Wayne1960 » Mon Sep 21, 2015 7:56 pm
Thanks guys it's a strange one. I know the slides are all set perfect although adjusted slightly to get them balance with carbtune.
I adjusted all the air pilots using a colour tune and it clearly showed the mixture turning blue as I wound in the jet in on the 4th carb and clearly made the bike run much better.
If I owing it out it starts popping and the plug gets wet.
I guess I need to try the checks from Z
#68 PostAuthor: z1bman » Mon Sep 21, 2015 8:23 pm
look at the fuel & air flow diagram in the manual & it will make it easier to diagnose
Wayne1960
#69 PostAuthor: Wayne1960 » Mon Sep 21, 2015 9:24 pm
Ok
Wayne1960
#70 PostAuthor: Wayne1960 » Sun Oct 04, 2015 2:10 pm
Does anyone have a choke lever and bar for carbs. the lever on mine has been missing ever since i got the bike.
Wayne1960
#71 PostAuthor: Wayne1960 » Thu Oct 08, 2015 6:01 am
Git replacement rubbers from Zpower. Think the old original were sucking in air causing most of my problems.
So putting carbs back on is always fiddly !! Am I doing it right?
Put clips in to rubbers and push carbs fuly home.
Tighten clips
Puts clips onto rubber boots and fit from inside working out.
Clips always get in the way!
Do you guys Spring your clips on after or put them over the boots and struggle?
Wayne1960
#72 PostAuthor: Wayne1960 » Sat Oct 10, 2015 5:56 pm
Think I can finally close this topic and bike all back together .
The problem
Rubbers between carbs and engine.
What a difference!
Thanks guys for sticking with me.
#73 PostAuthor: z1bman » Sat Oct 10, 2015 6:01 pm
about bloody time :lol: :lol: :lol:
Wayne1960
#74 PostAuthor: Wayne1960 » Sat Oct 10, 2015 6:34 pm
Ha its my OCD and a special thanks to you Z you have been very patient but it has been worth it on my part.
Now what am I gonna do!
I'm thinking of building a Spitfire!
Anyone interested?
Z1parR
#75 PostAuthor: Z1parR » Sat Oct 10, 2015 7:55 pm
Just buy one already done Wayne , don't arse about building one :wink:
0172 . Geoff Parr
Users browsing this forum: No registered users and 104 guests
