Calipers
King of Kings
Calipers
#1 PostAuthor: King of Kings » Sun Jul 05, 2015 10:29 pm
Does anyone know for sure if Z1000A1 front brake calipers are the same as the KH500-76 model? :) Will they fit the triples fork leg lugs/holes? Ta.
ColSZ1B
CALIPERS
#2 PostAuthor: ColSZ1B » Fri Jul 10, 2015 9:36 pm
Speak to Z Power.They will put you straight.
#3 PostAuthor: z1bman » Fri Jul 10, 2015 10:21 pm
different part no's so technically no they are different but that doesn't mean they wouldn't fit the difference is probably the location of the bleed nipple
Garn 1
#4 PostAuthor: Garn 1 » Fri Jul 17, 2015 12:33 am
I think these Z1000 calipers are designed to mount behind the fork legs, hence the change in bleed nipple position as Z1Bman mentions.
Thinking further, I think it's only the Z1000A2 that has these nipples mounted to suit the caliber behind the fork-legs?
