If you can help it would be great & I'd really appreciate it THANKS
Johny B
z1bman wrote:do you mean these ?
Thanks for that but NO what you show there are Float needle valves & I need Needle valves......these are the Brass tube that the main jets screw directly into. Thanks again though.
http://www.kawasakioriginalparts.com/ka ... =16030-027
zed1015 wrote:The needle JETS are the small brass insert that are a snug press fit in the venturi floor.
These are held in place by the immulsion tube also know as main jet holder.
Which parts do you need ? as all these are available from NRP Keyster and are accurately made in my experience.
It is the needle jet that wears oval along with the jet needle itself so ideally they should both be replaced as pairs at the same time.
DavidZ1R wrote:NRP Carbs in Manchester, just bought four myself for £40 plus postage, fitted and working great, they know their business! on tinternet. 0161 832 8646
njwmct wrote:If you need just the needle jets you can get them from Allens Peformance
The Z1R uses the same carbs as the Z1000 Mark 2 - Mikuni VM28SS
The needle jet part no. is 258 O-1 (Allens got me the Geuine Mikuni items from Japan).
http://www.allensperformance.co.uk/
Check you needles for any wear - if they are worn you need to replace the needles / needle jets at the same time.
The correct needle is 5CN 15
Users browsing this forum: No registered users and 109 guests
