UNLIMITED LTD - The Pigford Project
neilbarrett
#31 PostAuthor: neilbarrett » Fri Oct 24, 2014 6:21 pm
on the subject of brakes ,I like the rear shoe brake on a z1 ,it has a direct feel back to the lever & the foot, would a front shoe brake be better than the crap z1 single disc :?:
#32 PostAuthor: Pigford » Mon Oct 27, 2014 8:58 pm
I have "rejuvinated" an old V&H pipe..... but as of tonight I got a nice handmade s/s Harris replica - also has option to swap with a Piper style end can - off good old eBay.
Last night I got the tank off and found a pair of Green Dyna coils already fitted.... then took the carbs off and fitted a manual cam chain adjuster and some oil cooler take-offs.
At work I cleaned up the Z650 yokes and the front end just needs new headrace bearing then I can fit them.
Also got some new carb rubbers & think I'll fit me VM29 smoothbores c/w bellmouths :twisted:
#33 PostAuthor: Pigford » Tue Oct 28, 2014 6:33 pm
Here's the oil cooler take-off's, cam chain adjuster & new carb rubbers fitted:
Also fitted my spare Z1000 paint set & the new side panels I won in the Z1OC raffle at Blackpool:
With a twin outlet Pingel (+ reserve)...
Found the ER6n light I had stashed away for the last couple of years - it'll look smart:
Here's the exhaust I'm getting..
... so I may sell the V&H :?:
#34 PostAuthor: Ginger Bear » Tue Oct 28, 2014 6:38 pm
Piggy, Are you buying back the zorst that you sold with 'bestest' Zed :?
# 104
#35 PostAuthor: Pigford » Tue Oct 28, 2014 6:42 pm
Ginger Bear wrote:Piggy, Are you buying back the zorst that you sold with 'bestest' Zed :?
Nope - thats a different one..... the one on me old Bestest Zed was by Dave ExhaustCraft...... the new one will be with me tomorrow hopefully :P
sanderz
#36 PostAuthor: sanderz » Tue Oct 28, 2014 7:34 pm
Looking good there Mr Pigford - that ER6n back light sits neatly in the tail piece.
Wots up DOHC
garyd
#37 PostAuthor: garyd » Tue Oct 28, 2014 8:00 pm
Off topic question.
Is that one of those Shark Raw helmets I see in the pictures?
If so, what are they like?
#38 PostAuthor: Pigford » Tue Oct 28, 2014 8:04 pm
garyd wrote:Off topic question.
Nice & light - more of a summer helmet tho' as it's a bit noisy & breezy with windrush :lol:
#39 PostAuthor: Pigford » Fri Oct 31, 2014 6:41 pm
Brief update:
I have fitted the older Z1000 front end c/w Z650 yokes... but this has raised a couple of points which I wasn't aware of :roll:
1: The clock mounting arrangement is different.
2: And so is the wiring.
Not insurmountable, but a PITA :lol:
I've also changed the R/H switchgear as the LTD has lights ON all the time - so again more wiring changes.
Photo's to follow :!:
#40 PostAuthor: Pigford » Sat Nov 01, 2014 6:38 pm
Had a bit of a sort out in the garage - as I couldn't find me round cam cover :roll: But found it at last......
The wiring needs a bit of a sorting :shock:
Luckily also had an ignition casing as the one fitted was a bit mullered. So I removed the square cover and decided to check the valves. All looked good inside and only a couple needed opening up, one from 280 - 270 and another 260 to 255, so well pleased.
Here's the different top yokes - need to paint the bare metal one now so I can fit the clocks easily
Wheeled the bike out and took a shot of the bike with the new/old front end
Making some slow progress - don't think the cam cover will fit without messing about - not only does it foul the chain idler! but the exhaust valve "air emission" intakes need blocking up :evil: Hey-Ho, all good fun.
#41 PostAuthor: Ginger Bear » Sat Nov 01, 2014 9:02 pm
Looks like the 'hound' is eying up that back wheel as a good place to piss. :evil:
# 104
#42 PostAuthor: kev edwards » Sat Nov 01, 2014 9:08 pm
Mark, when I first bought my thou it had a foobarred yoke and I could only get 650 yokes at the time but they touched the tank so I had to make a mod to the steering stops, hopefully you don't have to do this to yours.
#43 PostAuthor: Pigford » Sun Nov 02, 2014 9:21 am
kev edwards wrote:Mark, when I first bought my thou it had a foobarred yoke and I could only get 650 yokes at the time but they touched the tank so I had to make a mod to the steering stops, hopefully you don't have to do this to yours.
Think you're right - time will tell :??
#44 PostAuthor: Pigford » Sun Nov 02, 2014 7:28 pm
Swapped some more bits around - fitted the other yoke and also changed the speedo drive for the original LTD one as the cable fitting is different :roll: the thread is larger on the drive.
The cam cover difference seems to be extra clearance for the cam sprox on the MKII cover - therefore the Z900 type touches the cam chain on the sprox.
Dug out some bling - my braided throttle cables :lol:
....which are now connected to the VM29 smoothbores...
It'll be a case of messing with the wiring next :shock:
needaz1100r
#45 PostAuthor: needaz1100r » Sun Nov 02, 2014 8:49 pm
[quote="Pigford"]
Please put some sleeving on those braided cables, they act like a file without - the hole in this swing-arm was caused by a braided brake hose.
Mark.
