kawasaki z1000 a1
PaulMceleney
- Chunks
kawasaki z1000 a1
clutch stuck went to use my bike tonight put the bike in first gear released the clutch and does not move try adjusting the clutch still nothing do I need to take the clutch apart
Check that the front sprocket nut hasn't come adrift allowing the sprocket to slip off the splines before stripping the clutch.
If the sprocket isn't the cause then slackening the clutch pushrod adjuster should enable the plates to bite under normal circumstances.
If that doesn't work then there's something jammed or broken in either the pushrod or clutch pack.
Have a decco through the oil filler hole see whats happening,sometimes a bit off careful prising with a broad blade driver can free up stuck plates...
PaulMceleney
- Chunks
- Mark Tiller
jphaynes669
- ZedHead
- Mark Tiller
PaulMceleney
- Chunks
