colourtune
weaver
colourtune
#1 PostAuthor: weaver » Mon Feb 03, 2014 6:29 pm
has anyone used one on their bike?Is it worth using one and am I right in saying using one and adjusting the fuel/air screw is only adjusting the mixture at tick over?
kas750
Re: colourtune
#2 PostAuthor: kas750 » Mon Feb 03, 2014 6:54 pm
weaver wrote:has anyone used one on their bike?Is it worth using one and am I right in saying using one and adjusting the fuel/air screw is only adjusting the mixture at tick over?
I used one on my Z1 and it was pretty effective..that said I could easily get it to a similar setting tuning it by ear..and yes it does only check the mixture at idle..
weaver
Re: colourtune
#3 PostAuthor: weaver » Mon Feb 03, 2014 7:05 pm
cheers mate,might get one out of interest to see what its like after fitting the dynojet kit
kwak1261
#4 PostAuthor: kwak1261 » Mon Feb 03, 2014 7:16 pm
Ive just set the carbs on my Z1300 with a colortune.
found it very easy to use.
if it cant be fixed with a hammer then it must be an electrical fault.
#5 PostAuthor: PAULJAC47 » Mon Feb 03, 2014 7:21 pm
https://www.google.co.uk/search?q=color ... Fwww.carbt
Good bit of kit check out the colour charts,i have had a fair bit of sucess with mine,there are a number of tests you can carry out...
