Stearing column bearings
Wayne1960
#1 PostAuthor: Wayne1960 » Tue Dec 10, 2013 12:45 pm
How do you get the bearing shells out of the steering column top and bottom!! is there a special tool? the z training video makes it look real simple.
Bike now finished what a joy!
bollypne
#2 PostAuthor: bollypne » Tue Dec 10, 2013 1:12 pm
Seem to remember just knocking mine out with a bar of some sort, seemed fairly easy too.
Big Bol
Z900, ZRX1200r & a Z900rs Cafe
KeithZ1R
#3 PostAuthor: KeithZ1R » Tue Dec 10, 2013 1:50 pm
get some 25mm round steel bar and wack em out, failing that you can cut em with dremel to make it easier.
I assume you have no intention of putting em back ?
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
bollypne
#4 PostAuthor: bollypne » Tue Dec 10, 2013 3:48 pm
I love my dremmel. Had to cut the bearing shells out of my ZX10 as there was no where to get a bar on to.
Big Bol
weaver
#5 PostAuthor: weaver » Tue Dec 10, 2013 4:00 pm
big green bus
#6 PostAuthor: big green bus » Thu Dec 12, 2013 9:07 am
weaver wrote:I use one of these,works a treat
http://www.ebay.co.uk/itm/HEAD-PIPE-OUT ... 23276d02fe
me too, stevew just welds a bit of bar to the bearing to tap out works every time
malmojoe
#7 PostAuthor: malmojoe » Thu Dec 12, 2013 9:20 am
if you've got a welding kit, run a bit of weld around it and they drop out. Or heat the headstock up and get a socket on a long extension bar and gently tap around keeping it as level as possible as it comes out.
oldtimer
#8 PostAuthor: oldtimer » Thu Dec 12, 2013 10:04 am
I applied heat and knocked them out with a piece of square bar I had knocking about.
If I was to do it again I would invest in the correct tools for removal and installation.
Doesn't anyone rent the tools out or don't the Z1OC have the tools to lend to members?
****** If applying heat, watch you don't burn the paint or melt the powder coating on the headstock ..... ask me how I know :oops: *******
KeithZ1R
#9 PostAuthor: KeithZ1R » Thu Dec 12, 2013 10:21 am
The trick is in the weight of knocking stick you use :D and I found from trial and error a 4lb lump hammer and the round bar achieved the required result without any removal of paint :lol:
Keith
:bop :gom
mistaken.
Serps
#10 PostAuthor: Serps » Thu Dec 12, 2013 7:20 pm
Have a look at bikers tool box, think you may even get a discount.
http://www.bikerstoolbox.co.uk/acatalog ... inema.html
#11 PostAuthor: z1bman » Fri Dec 13, 2013 1:01 pm
this is what i use genuine bmw bearing puller made by kukko germany simple & easy to use
Wayne1960
#12 PostAuthor: Wayne1960 » Mon Dec 16, 2013 3:00 pm
Thanks for all your help. Had to give in and just ordered the one from bikers tool box.
Wayne1960
#13 PostAuthor: Wayne1960 » Thu Dec 19, 2013 8:43 am
what a nightmare, the special drift tool i ordered turned up yesterday and it looked perfect. Good quality and looked like it would do the job. I tried it this morning and it felt like it would work then slid straight past the bearing lip both top and bottom!!!!!!!! the guy makes it look so easy on the Kawasaki training video.
Thanks for all your suggestions ill keep trying.
