z1a carbs
Sorry I have nt got any.
Creeping wont help, rarer than hens teeth. Having said this, some one will offer you some for sure.
Z1 Enterrises carb guide, click on pictures and they enlarge, hope it helps.
http://www.z1enterprises.com/Z1CarbGuide.aspx
- Z903
Wired George has good info on his site as well regarding these:
http://www.wgcarbs.com//index.php?option=com_content&task=view&id=Itemid=92
ADRIAN H wrote:Z1 Enterrises carb guide, click on pictures and they enlarge, hope it helps.
An excellent piece of info.
Jimmock.
I hate people I don't like !
- z1000puddin
- Tonka
ogre wrote:cheers tonka if you will and thanks for your input jimmock you greedy b*****d only joking but i could feel a poem coming on
Hi, just sent you a PM but if you have an engine starting with 38... they should have the later 28mm Mikuni carbs with the small drain screw angled to the side of the float bowl and not the 17mm drain plug. These are the carbs I have.
Gez has seen these and he thought they have not done many miles but they def need a ultrasonic clean (Arizona dust in them as this is where they came from when I bought them off ebay). The carbs tops will also need a a good polish. The yellow paint is still on them and they have never been adjusted by the looks of things.
Inheritance? What inheritance? He spent it all on booze, women and Zed parts!
malmojoe
