rubber rear fender
alinus65
rubber rear fender
#1 PostAuthor: alinus65 » Tue Mar 19, 2013 7:52 am
HI,
I complete the installation of the rear fender but I realized that I missed to install the two rubbers with number 92075-135.
From the drawing is not clear where I should fit them.
Any help?
LondonZ1
#2 PostAuthor: LondonZ1 » Tue Mar 19, 2013 3:32 pm
I think that these go at the inner end of the tool tray/handbook recess. They fit into two holes in the tail unit. If I am right, then they are also quite tricky to fit as there is minimal clearance between the hole and the underside of the tail unit. I have solved this problem by deciding not to fit them.
I may be wrong, so corrections welcome.
#3 PostAuthor: z1bman » Tue Mar 19, 2013 5:19 pm
THEY FIT ON THE INSIDE OF THE FRAME AT THE REAR WHERE THE INDICATOR MOUNTING BRACKET IS WELDED TO THE FRAME. THERE ARE TWO SMALL SQUARE MOUNTINGS WELDED TO THE FRAME WITH A HOLE IN THE MIDDLE + THE RUBBERS ARE FITTED THERE TO PREVENT THE REAR FENDER MOVING BETWEEN THE FRAME WHEN FITTED THEY WILL MAKE THE MUDGUARD A TIGHT FIT IN THE FRAME
Bill Newman
#4 PostAuthor: Bill Newman » Tue Mar 19, 2013 7:13 pm
z1bman wrote:THEY FIT ON THE INSIDE OF THE FRAME AT THE REAR WHERE THE INDICATOR MOUNTING BRACKET IS WELDED TO THE FRAME. THERE ARE TWO SMALL SQUARE MOUNTINGS WELDED TO THE FRAME WITH A HOLE IN THE MIDDLE + THE RUBBERS ARE FITTED THERE TO PREVENT THE REAR FENDER MOVING BETWEEN THE FRAME WHEN FITTED THEY WILL MAKE THE MUDGUARD A TIGHT FIT IN THE FRAME
Spot on
alinus65
#5 PostAuthor: alinus65 » Tue Mar 19, 2013 10:40 pm
Done, thanks
DogsbolloxofZ1B
#6 PostAuthor: DogsbolloxofZ1B » Wed Mar 20, 2013 6:44 pm
Any images of the finished bike?
Mike
alinus65
#7 PostAuthor: alinus65 » Wed Mar 20, 2013 9:33 pm
Not yet finished.
Yesterday evening I was installing the carbs and I realised that there were installed 4 carbs rubber holders rights ( :cry: ). I ordered the two holder left.
Waiting for cylinder for front caliper plus few more things.
Next weekend I am travelling for work.
Hopefully Easter week end I will try to push the start button
Photos will follow....
Ciao :clap
Users browsing this forum: No registered users and 82 guests
