26mm carbs
ash
26mm carbs
#1 PostAuthor: ash » Sun Oct 14, 2012 7:11 pm
Whos got a picture of the underneath insides of a set of 26mm carbs, mine dont seem right for some reason,
Garn 1
#2 PostAuthor: Garn 1 » Sun Oct 14, 2012 10:43 pm
Ash, sorry no picture as yet!
What you are probably looking at is the difference in the Air/fuel screw adjustments. The later Mikuni 26mm carbs had a fuel adjustment screw at the bottom closest to the head, whereas, the earlier carbs had the short spring loaded Pilot air adjustment on the top.
ash
#3 PostAuthor: ash » Mon Oct 15, 2012 5:53 am
Garn i will put a picture on later then you can see, not got a manual to do any references, mine should have the later 32mm cvs on them but the bike came with the 26s, theres no main jet thats for sure, and the only air screw from what i can see is on the top, little brass screws that sit offset either side of the carb bodies, i do know from the past that some of these carbs had a 1.5 or 1.7 idle jets, these dont have them either, :o
ash
#4 PostAuthor: ash » Mon Oct 15, 2012 1:30 pm
Garn heres some pics of my carbs, see what you make of them,
Posted: Mon Oct 15, 2012 1:30 am Post subject:
[img]http://i5.photobucket.com/albums/y190/kwakadude/IMGP0019_zps8f39e273.jpg[/img
Deff no main jets or idles jets
#5 PostAuthor: chrisu » Mon Oct 15, 2012 1:54 pm
no pilot jets, mains or emulsion tubes in there !
try nrp carbs.................
ash
#6 PostAuthor: ash » Mon Oct 15, 2012 1:55 pm
Chrisu just what i thought, now if anyone has any i,ll buy them off um,
#7 PostAuthor: chrisu » Mon Oct 15, 2012 1:57 pm
they're not A4 carbs though.................
only a single fuel feed and A4s have 2 feeds - to left/right bank of carbs.
ash
#8 PostAuthor: ash » Mon Oct 15, 2012 1:58 pm
Dont know the setp up with the 26s so if anyone does let me know,
I,ll be running filters so i can judge from there what main jets to go for,
ash
#9 PostAuthor: ash » Mon Oct 15, 2012 1:59 pm
Chrisu single feed with vacum pipe to tap,
#10 PostAuthor: chrisu » Mon Oct 15, 2012 2:08 pm
z1000 then............... probably A2 given the vaccum takeoff on the fuel tap.
i'm sure someone more knowledgeable than me will be along to recommend main jet size uplift.........
#11 PostAuthor: kev edwards » Mon Oct 15, 2012 2:14 pm
Looking at the ribs on the slide housing tells me the are 650 carbs, i've never seen ribbed on 900s or thous.
ash
#12 PostAuthor: ash » Mon Oct 15, 2012 2:17 pm
Yes they are z650 carbs off my z650,
ash
#13 PostAuthor: ash » Mon Oct 15, 2012 2:19 pm
Kev seeing as i aint got a manual i just need the spec , eg main jet, idle jet size and whether anyone on here have the parts i need
Crofty
#14 PostAuthor: Crofty » Mon Oct 15, 2012 2:52 pm
ash, they are 24mm 650 carbs, you were asking about 26mm carbs as fitted to Z900A4 etc
I think I might have some emulsion tubes and mains etc, pm me if you need me to check.
Thought you were doing webers?? or maybe your thinking of going to 26mm in future. I'm like jimmock, confused
btw they look to be reasonably clean inside and also they did a 22mm version with ribs on as well, but not on many models of 650
ash
#15 PostAuthor: ash » Mon Oct 15, 2012 3:15 pm
Sorry thought the 650s had 26s seeing as mine suppose to have 32mm cvs as standard,
Pm sent mate :D
Forgot to say, the manifold dosent fit the 650 head so its a no no on that at the moment, holes are out of line by a long way, unless i can get some adapter plates made im gonna leave it for now,
Users browsing this forum: Google [Bot] and 108 guests
