http://www.ebay.co.uk/itm/kawasaki-z1-z ... 2ebcc7b8c7
Or something else
chrisNI wrote:If the Mikunis are anything like the Keihins they don't respond well to gauge setting anyway even if you have take offs, from what I've found and subsequently been told. You balance them up on the bench using the wire adjustment method which I think is in the manual anyway.
FOZ1A wrote:John, I run these on my bike and use the standard inlet rubbers. They are a perfect fit and balanced them using the vacum take offs. I have been using the for 3 yeas and never had a problem!
foz
chrisNI wrote:I got a set of Keihin CRs they fit the standard rubbers, but when i set them up the usual way on the guages it made the bike run like shit. I spoke to a club member who knows a lot about CRs he told me it was a waste of time on gauges, and using the method which I think is described in the factory Z manual for setting the slides using a fine wire to measure the slide heights all equally would work better. on the CRs it certainly did. Maybe the Mikunis will balance ok on the gauges if people have found them ok.
foz
Users browsing this forum: No registered users and 128 guests
