Fuel filter
DaveZ1
Fuel filter
#1 PostAuthor: DaveZ1 » Mon Jan 30, 2012 8:11 pm
Hi all, I am looking for one of those small plastic filters that fits on the fuel tap in the tank.
There are two one for the main one for the reserve, I took the tap off the tank and one of
them is missing. Dont believe you can buy just a filter and dont fancy forking out for a
complete new tap.
Cheers, Dave
#2 PostAuthor: z1bman » Mon Jan 30, 2012 8:48 pm
KAWASAKI FUEL FILTER 49019-1085
Mark Tiller
#3 PostAuthor: Mark Tiller » Mon Jan 30, 2012 9:51 pm
there is only one for reserve not for the tall tube (main)
07962421462
#4 PostAuthor: z1bman » Tue Jan 31, 2012 7:36 pm
DaveZ1
#5 PostAuthor: DaveZ1 » Tue Jan 31, 2012 11:49 pm
Mark Tiller wrote:there is only one for reserve not for the tall tube (main)
Hello Mark, these two photos are from Z power catalogue. Looks like there is
two but i think they are the same part number 49019-1085 Cant find anywhere on the net to get one.
DaveZ1
#6 PostAuthor: DaveZ1 » Wed Feb 01, 2012 12:01 am
z1bman wrote:http://www.ebay.co.uk/itm/KAWASAKI-FUEL-FILTER-49019-1085-GPZ-ER-EX-500-250-NINJA-/230696319013?pt=UK_Motorcycle_Parts&hash=item35b6927825
Thanks for the pointer Z1Bman :D but that seller sold the last one earlier in january :( I have e-mailed him to see if he can source another for me no reply as yet
#7 PostAuthor: z1bman » Wed Feb 01, 2012 10:11 am
they should still be available from Kawasaki dealers as it is still a current part
Mark Tiller
#8 PostAuthor: Mark Tiller » Wed Feb 01, 2012 5:22 pm
Apologies...i stand corrected, none of mine had it on the long tube (Z1000As)
07962421462
pertonpc
#9 PostAuthor: pertonpc » Wed Feb 01, 2012 5:40 pm
Hi Guys
If you can't source one from kawa I am told that lawn mowers use a similar filter (the petrol ones :!: )
So try your nearest mower repair/ service centre.
If the plastic filter is loose on the tube my tip was to run some solder round the top of the tube until it is snug.
Cheers from Mark
DaveZ1
#10 PostAuthor: DaveZ1 » Fri Feb 03, 2012 10:01 pm
Cheers guys I got sorted, the link Z1b man posted came up trumps :up , had one left after all :D
rodge70
#11 PostAuthor: rodge70 » Sat Feb 04, 2012 11:02 am
here is the mower filter,H**** gx range .Image.
sorry if pic is a bit big,way to technical for me to change,the rubber collar helps hold the filter in place as not a perfect fit in tap hole.
