indicator relay
wayno
indicator relay
#1 PostAuthor: wayno » Fri Aug 26, 2011 6:11 pm
does the power to the indicators travel throught the flasher relay before the switch or after the switch/ cannot get power at the bars.
#2 PostAuthor: z1bman » Fri Aug 26, 2011 6:28 pm
brown wire at the relay should be live when ignition switch is on. orange wire into the switch is the live feed to the indicators. if the brown is live at the (relay) + you've got no power at the orange at the switch the relay is your problem
#3 PostAuthor: Rich » Sat Aug 27, 2011 7:44 am
through the relay and then to the switch which "turns" it left or right
wayno
#4 PostAuthor: wayno » Sat Aug 27, 2011 10:10 am
Rich wrote:through the relay and then to the switch which "turns" it left or right
so if relay is knackered then that could be it?
KeithZ1R
#5 PostAuthor: KeithZ1R » Sat Aug 27, 2011 10:19 am
Do the lights come on and dont flash :?: then the contacts have welded shut, or if the dont come on at all peel it open carefully a the bottom, it may well be the the bi-metal strip is stuck open they get a bit tired after a while. if your gentle you can "adjust it" so it touches and then it should be ok :) ..........or if you cant be arsed just get a new one :lol:
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
#6 PostAuthor: Rich » Sat Aug 27, 2011 11:59 am
just short the two connectors going into the relay, that will show if it is working or not
wayno
#7 PostAuthor: wayno » Sat Aug 27, 2011 12:17 pm
yep, its the relay, thanks all :D
Users browsing this forum: No registered users and 96 guests
