I would like to be able to identify a Z1, Z1A, Z1B, Z900, Z1000A1 & A2 crankshafts from later models [J model] cranks.
The things I know are that the Z1 series crankshafts:
Have 15 teeth on the crankshaft centre sprocket.
They have a keyway slot on the rotor taper. (not 100% sure about Z1000A1 & A2.)
What else should I look for?
How many teeth have later cranks?
The later cranks have shorter con-rods and lower crank-pins in pistons (I learnt this from a posting yesterday!)
Any help would be appreciated.
Z1 Crankshaft v's later (J) Crankshafts
- london calling
Z1/Z9 cranks and subsequent z1000's with round camcover all have 15t on crank with matching 30t cam sprockets. Early z1 and 9's have lighter (porkchop) crank. Some have keyway, some not but are all interchangable with no other mods. Later mk2 /st with square camcover have 16t on crank and fatter alternator taper, these will fit early motors but you must use matching 32t cam sprockets and corresponding alternator rotor. All are roller type camchain... J and gpz cranks are hy-vo (silent) type camchain ... For identification purposes all this is presuming you are dealing with standard unmodified engines as all parts are interchangable throughout the range with a small amount of work. i.e you could easily come across an early 9 motor with a mk2 or jeep crank , any model head and a gpz gearcluster fitted.
- paul doran
Hy-Vo fitted to models after 1980 i believe.
As Paul says its a begger to set the cam timing because they jump teeth just as soon as look at them.
The funny looking bendy bracket is used to hold the chain close to the sprockets whilst setting up.
They run on slipper blades as opposed to toothed gear wheels and the barrel, head, crank, cam cover and crankcase mouth is different to be able to accept them.
http://s254.photobucket.com/albums/hh86 ... 20dialler/
