numbers under tank
numbers under tank
do the z tanks have numbers underneith for a reason,i have found some stamped at the rear underneith near the strap lug.
Davy Doherty
Davy Doherty wrote:Early tanks as you say are the one's which take the small badge, the seam under went right through to the end of the line Z1B!!
Davy is correct, the seams remained the same through to 1975 Z1B .The Z1 tanks had 122mm between tank emblem screws and the later Z1A and Z1B had 140mm...I think.
Dxyselia rlues, oaky.
http://www2.b3ta.com/youcantspell/
That number could be 2024 on close inspection (Note: I think if it was ending with a 1, it would have a bar at the bottom of the downstroke).
On these tank stamping....... Some years ago, I did a bit of research on a batch of about ten Z1 series tanks, on a WorldWide forum that is now redundant [as regards to history].
I listed them all, in respect to known model Z1 series year, badge size and that tank stamped number, [including some A4 tanks]. I must say, I found no logical sequence, other than to say, they must have been a manufacturing batch sequence. Some had no marking at all, some had 3 digit numbers, some had alpha-numeric stamping! It was not a fruitful exercise, as a matter of fact, it was a failure! Readers of that forum also contributed, with no logical conclusion.
RegardZ.
RegardZ.
Users browsing this forum: gray and 99 guests
this is the number.
