Replacement engine cover screws
Robw
#1 PostAuthor: Robw » Mon Mar 02, 2009 6:49 pm
I need to replace all the screws that hold on the clutch cover etc, I know MandP do alloy screw sets, but ideally I am after stainless.
Any suggestions
Cheers Rob
Mark Stratton
#2 PostAuthor: Mark Stratton » Mon Mar 02, 2009 7:04 pm
Rob try www.inoxgrp.co.uk they normally can help and their gear is top quality.
phil churchett
#3 PostAuthor: phil churchett » Mon Mar 02, 2009 7:05 pm
Helped these out a few years ago with sizing bolts/screws for Zeds.
Very helpful guy, [sorry can't remember his name].
http://www.inoxgrp.co.uk/homepage.htm
Robw
#4 PostAuthor: Robw » Mon Mar 02, 2009 7:11 pm
Cheers guys, will do.
Rob
Steve Cooke
#5 PostAuthor: Steve Cooke » Mon Mar 02, 2009 7:16 pm
Look up a company called A2 / A4 Fixings they have them all, as long as you have the sizes from a parts manual or somewhere. Also if you're changing to socket caps there's no problem, but if you want Phillips type heads to keep along original lines be aware that the heads on stainless ones are often larger than standard Kawasaki ones.
Taffus
#6 PostAuthor: Taffus » Mon Mar 02, 2009 8:36 pm
phil churchett wrote:Helped these out a few years ago with sizing bolts/screws for Zeds.
John Kemp, very helpfull knows his stuff too :D
compo z1r
robw
#7 PostAuthor: compo z1r » Mon Mar 02, 2009 9:07 pm
phil denton from CMM mag do them in stainless or will if you ask. :wink:
THE ORIGINAL TARMAC TERRORIST
Z1OC # 886 till 2030
Pasc
Re: robw
#8 PostAuthor: Pasc » Tue Mar 03, 2009 11:15 am
compo z1r wrote:phil denton from CMM mag do them in stainless or will if you ask. :wink:
Make sure you are sitting down before looking at his prices :??
