z650 neutral light switch
BustedKnuckle
#1 PostAuthor: BustedKnuckle » Wed Jan 17, 2007 1:05 pm
Hi,
I am doing up a 1981 z650
I have a couple of problems and was wondering if anyone can help.
I have a leak coming from the gear selector shaft and it looks like the seal is knackered the clutch push-rod oil seal is also leaking. Any tips or hints on doing the job would be appreciated.
The neutral light does not work. I have tested the wiring and that seems ok. I think it is probably the switch, but I am not sure how to test it.
Ed Z1-R
#2 PostAuthor: Ed Z1-R » Thu Jan 18, 2007 7:53 am
Wang em out mate but when you re-fit use a socket the same diameter as the seal and GENTLY tap em in until the "hollow" sound goes to a "solid" sound where by you know its seated home :wink:
BustedKnuckle
#3 PostAuthor: BustedKnuckle » Thu Jan 18, 2007 3:10 pm
Cheers mate, off to do some wanging :lol:
Any ideas on the neutral light?
Ed Z1-R
#4 PostAuthor: Ed Z1-R » Fri Jan 19, 2007 12:14 pm
Good show :!: :D
